Volvo 2003 engine raw water problem - Page 2 - SailNet Community
post #11 of 12 Old 04-05-2009
Hello Captain:
I have a Volvo 2002 (one less cylinder), but check to see if the plastic gear connected to the fly wheel (that turns the impeller) is broken--thus not turning the shaft. It happened to me once, and is fairly easy to fix. The plastic gear that drives the pump is plastic on purpose as I discovered since if the water there is frozen, the plastic gear breaks before doing serious damage to the flywheel (which would be a major problem, of course)
Moe
Crishelle
ChrisCraft Apache 37 sloop
mgiguere is offline
post #12 of 12 Old 04-05-2009
Do you know if the cooling pipe in the tranny is a coil, or a straightish run? If it's not a coil perhaps you can get a piece of welding rod (the TIG type, not the insulated arc type) and try to feed it through.
Barring that, can you get a small portable compressor and put some real pressure behind the blockage? I'd try the reverse flow direction first...
Faster is online now
Volvo MD 2030 Engine Failure - Lack of Support firehoser75 Gear & Maintenance 20 01-18-2009 10:19 AM
READ THIS TODAY-It may save you an engine or at least some time and money! Marleetet Gear & Maintenance 6 07-14-2008 05:28 PM
Overheating HELP !!! Culinary411 Gear & Maintenance 19 08-07-2007 06:33 PM
Raw Water in Engine wmwtlw Gear & Maintenance 3 02-25-2001 12:31 PM
Safety Check Mark Matthews Gear and Maintenance Articles 0 01-25-2000 08:00 PM
