10-30-2002
50amp a/c service
L5 is the proper plug to use at most marinas. While these look like high voltage plugs, i.e.: rounded, twist-lock type, there actually 120v outlets with the higher amperage available. Check with the dock master. He should be able to assist you. If he can''t, switch to another marina... Quick!
