Martec Prop Cotter Pins - Page 2 - SailNet Community
post #11 of 14 Old 04-04-2009
Sea Slacker
Originally Posted by Fstbttms View Post
This doesn't even make sense.
why not?
brak is offline
post #12 of 14 Old 04-04-2009
I don't discuss my member
Fstbttms's Avatar
Originally Posted by brak View Post
why not?
1.- The size of the shaft relative to the pins and its position relative to the prop and boat do not affect whether or not, or to what extent, electrolytic corrosion will occur.
2.-
Pins are small and they are between prop and water...
so since stainless is less noble than bronze, pins will act as sacrificial anodes and may dissolve relatively quickly.
The first part of this sentence (besides being completely irrelevant) has absolutely no relation to the second part.
3.- The pins are made of monel because monel is galvanically closer to bronze than stainless is (as you correctly pointed out). However, this is to prevent galvanic corrosion, not electrolytic corrosion.
Fstbttms is offline
post #13 of 14 Old 04-04-2009
Sea Slacker
[QUOTE=Fstbttms;470918]1.- The size of the shaft relative to the pins and its position relative to the prop and boat do not affect whether or not, or to what extent, electrolytic corrosion will occur.
2.-
The two are intimately related, in particular when we are talking about prop shaft and anything attached to it. Practically all diesel engines are electrical ground for their alternators and as such, shaft/prop etc act as a ground path to the water (unless specifically disconnected through a coupler).
Boat ground is higher in potential than water and it does create current. Galvanic and electrolytic corrosion have essentially same mechanism - difference in potential created in one case by external source of electric potential and in another by different pontential between dissimilar metals in electrolyte.
Generally speaking simple difference of potential between stainless and bronze is not sufficient to create significant corrosion, but the ground current from the boat helps this process quite a bit.
brak is offline
post #14 of 14 Old 04-06-2009 Thread Starter
rperret's Avatar
gotcha...thanks.
Shaft is big, and it is also towards the boat from the prop. So the electricity flow is from shaft to prop to water. This prevents much corrosion occuring at shaft. Pins are small and they are between prop and water, so since stainless is less noble than bronze, pins will act as sacrificial anodes and may dissolve relatively quickly.
The beat goes on, the beat goes on...
The grocery stores the super mart, uh huh
Little girls still break their hearts, uh huh
And men still keep on marching off to war
Electrically they keep a baseball score
rperret is offline
martec feathering 2 blade prop j34035 Gear & Maintenance 2 03-13-2009 08:46 PM
martec prop refurb dvpamenter Gear & Maintenance 2 01-13-2008 02:31 PM
Changing prop underwater trantor12020 Gear & Maintenance 16 03-03-2007 12:02 PM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Martec Geared Folding Prop rtcooke Gear & Maintenance 1 05-13-2001 06:05 AM
