Old 07-15-2009
AdamLein's Avatar
AdamLein will become famous soon enough
Happily I've just run into exactly the same problem today. Exactly exactly (same boat even). I've started drilling into available end of the bolt but it's taking a long time and it's a real PITA... we've already broken one titanium drill bit. Hopefully not much more to go before I can turn the mast over and grind off the hex cap on the other side.
Couple of questions for you since you've been through it:
1) About how long did it take you to drill out the threaded end of the bolt? How deep did you go?
2) What setup did you use to grind the hex cap off the cap end of the bolt? I'll probably have access to an angle grinder. I don't think I'll have enough clearance to get between the cap and the tang. I'm considering grinding right through the old cast aluminum bracket to essentially cut off the bolt.
3) When the little bits of burning metal are flying around, how did you prevent them from getting all over your gelcoat (and your neighbors' gelcoat)?
4) Any other gotchas during the bracket replacement after that?
I'd say, "Thanks for having this problem three months ago," but I wouldn't wish this work on anybody. Thanks for solving this problem and posting about it, I guess
p.s. I can confirm that on the C27 the tang bolt hole is wide enough for the bolt, but not for the compression tube. The instructions that come with the spreader bracket retrofit kit from Catalina Direct suggest cutting a notch into a 20-or-so-foot-long PVC pipe and using that to feed the tube into the mast.
s/v Essorant
1972 Catalina 27
  #12
Old 07-15-2009
donlofland is on a distinguished road
1)I was using new drills, and it took 5-10' to drill the threaded end of the bolt down to just inside the inside wall of the mast. 2)I used a Saws All (?spelling) to cut the hex head off the bolt between the aluminum spreader bracket and the hex head. I found SS bolts cut fairly easily but are difficult to drill! Then ground it down flush with the outside of the mast and drilled until it fell inside the mast-by some fortuitous quirk of fate, the bolt did not spin as I drilled it. For grinding I used a grinding wheel on my drill...3) the mast was in my back yard, so flying bits of metal were not a problem. 4) the mast was stripped down to nothing but a bare extrusion, and the PVC pipe routine worked, but was very tricky. And they're right about not over-torquing the upper spreader bracket bolt-it's easy to dimple the mast! 5) Hope this helps! Good luck!
  #13
Old 07-15-2009
AdamLein's Avatar
That does help a lot. I have noticed that newer bits drill in pretty quickly... but then my newer bolt blew up and I switched to an older bit which was not significantly sharper than my thumb. I guess I'll grab some new bits and grinding wheels so that I'm not dependent on my friend's angle grinder.
As for the metal bits, I'm thinking of draping a wet bed sheet around the A-frame, which is still in place.
Thanks for your input!
s/v Essorant
1972 Catalina 27
  #14
Old 07-15-2009
fullkeel7 is on a distinguished road
Adam, If you are aware of this already, my apologies. In addition to using a sharp or new bit, the key to drilling SS or any hardened steel, is to keep the bit speed to a minimum. Heat is your worst enemy, so trying to drill into steel at the same speed as say aluminum, will only prematurely dull the bit and harden the steel. A little machining oil applied by a helper while drilling helps to cool things down as well.
  #15
Old 07-15-2009
In addition to what FULLKEEL7 said, you want to have the bit turning slowly enough that you can watch the individual flutes rotating... if you can't you're probably turning it too fast.
  #16
Old 07-16-2009
AdamLein's Avatar
Yep. My crew is much more tool-savvy than I am and they gave the same advice. We started off going slow and being generous with the oil. I found that the bit seemed to cut better (felt like it was cutting) at the lower speeds. However in spite of all the concern about heat, the bit never heated up... I think the mast might act as an enormous heat sink.
Anyway I think now it's time for a couple of sharp new bits to go at it... I feel like I'm not really making progress anymore.
s/v Essorant
1972 Catalina 27
You may post attachments
You may edit your posts
Mast, spreader, shroud design, help Talisman66 Gear & Maintenance 1 11-23-2008 03:41 AM
Getting a compression tube into mast sailboy21 Gear & Maintenance 1 08-17-2008 09:54 PM
Outboard Motor Bracket "not for use with 4 stroke engines" petertribo Gear & Maintenance 6 07-28-2007 07:49 AM
Broken Spreader augbug27 Gear & Maintenance 49 07-09-2007 08:47 PM
Packing gland coming out of top of rudder tube! duffer1960 Gear & Maintenance 2 08-25-2005 08:26 PM
SEO by vBSEO 3.6.1
