Old 04-05-2009
Pub911 is on a distinguished road
Ok if my prop shaft is sticking out further?
A new 'feature' of the ZF-6 transmission, as a replacement for the Hurth HSB 50, is that it's 1" longer. This means that the prop shaft is 1" longer at the business end. On my setup, this means I go from about 4" to 5" of exposed shaft between the end of the cutlass bearing and the prop, itself.
I know alignment is required regardless, but should I go through the hassel of have the shaft shorted, rekeyed, etc?
Clearance is not an issue.
Old 04-05-2009
scottyt is on a distinguished road
i cant see that as a real problem, but why did you not have it shortened ?
Old 04-05-2009
Cost and wasn't sure if I needed to shorten it.
Old 04-05-2009
Maine Sail's Avatar
The recommended
The recommended hang over distance between the cutlass bearing and the front edge of the prop hub is 1X the shaft diameter max. Beyond that and you can start to create shaft whip. 4" inches is way too much but 5" is really bad..
Per ABYC Standard P-06
6.5.5.4 The distance between the forward end of the
propeller hub and the aft end of the last strut bearing shall
be limited to one shaft diameter
______
-Maine Sail / CS-36T
Old 04-05-2009
my shaft is 1"...I don't think I could fit a zinc on the shaft if all I had to work with was 1".
Still, appreciate the reference and advice.
Old 04-05-2009
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
What kind of boat are we talkin' about?
"Clean bottoms are FastBottoms"
Old 04-05-2009
1972 NorthStar (aka Hughes) 38.
Fin keel skeg-hung rudder. 25hp diesel.
Old 04-05-2009
Fstbttms's Avatar
So the shaft exits the hull at the keel and is not supported by a strut?
Old 04-05-2009
correct. no strut. the length of the shaft overall is about 6' - in case that matters.
Old 04-06-2009
anthon is on a distinguished road
I wouldn't be comfortable with 5" of exposed shaft.
I'd get it shortened to 3" max.
Replacing Cutlass Bearing SeaDeucer Gear & Maintenance 15 04-17-2009 03:41 PM
Seafarer 26' prop shaft replacement jkimberly Gear & Maintenance 5 02-17-2009 11:04 AM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Drive Train Vibration Tom Wood Gear and Maintenance Articles 0 10-10-2002 08:00 PM
prop shaft thomasstone Gear & Maintenance 3 03-27-2002 03:03 PM
