Butyl tape underwater - Page 2 - SailNet Community
post #11 of 17 Old 04-06-2009
No one has suggested 3M 5200 superglue here... for a very good reason.
sailingdog is offline
post #12 of 17 Old 04-06-2009
Maine Sail's Avatar
Originally Posted by AjariBonten View Post
One Comment About Butyl Tape in Underwater Applications:
I work with underwater buoys that are deployed as deep as 2000 meters. The main body of these buoys is comprosed of a glass sphere that comes in two parts. The hemispheres are mated, a light vacuum is applied, and we seal the joint (on the outside of the joint) with butyl tape. Standard, off-the-shelf, glaziers butyl tape; and the tape has remained intact, pliable, and removable after as long as two years submerged.
(edit: we then wrap with a layer of Scotch 5200 electrical tape as a mechanical protectant)
While this is not a statement that it is the ideal candidate for Brak's application ; I can state emphatically that it will come out of the water in nearly the same state that it went in. Personally, If I were to do this job I might choose it over 5200 for the ability to remove it without using the nuclear option.
Very good info!!!!!!!!!!
______
-Maine Sail / CS-36T
Maine Sail is offline
post #13 of 17 Old 04-06-2009 Thread Starter
Sea Slacker
Cool Well, that makes me feel pretty darn good about it.
Sounds like a very interesting job btw. What are those buoys for?
brak is offline
post #14 of 17 Old 04-06-2009
pdqaltair's Avatar
Before I heard of butyl being use on boats on this site, use as a submerged sealant..
in refinery waste water plants was my experience. Years under water at all sorts of pH and salt loadings. The only things we watched for were heat (not over ~110F or it will creap) and high hydrocarbon levels in the water. If you enconter either of these limits, you have larger concerns!
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #15 of 17 Old 04-06-2009
Aquaholic
AjariBonten's Avatar
OOPS, sorry Sd, looking back I see you suggested 4200, not 5200, my bad.
Maine Sail; thank you I value your praise highly.
Brak:
The buoys are recording devices for marine mammals. We usually deploy them for 3 - 6 months where they record sounds in a pre-0determined frequency range onto hard drives. The data is extracted and analyzed to research whales mostly.
I work on the production and deployment team of the Bioacoustics Research Program at Cornell University. OUr websites are here:
The Science of Sound — Bioacoustics Research Program
Right Whale Listening Network, Cornell, Bioacousti
My job is building/maintaining these recording devices, as well as going into the field to deploy and retrieve them.
Thanks, it IS a cool job.
I got an Old Fat Boat
She's Slow But Handsome
Hard In The Chine, but Soft In The Transom
I Love Her Well, And She Must Love Me
But I think It's Only For My Money
..... Gordon Bok
AjariBonten is offline
post #16 of 17 Old 04-06-2009
Aquaholic
DUH, I must have 5200 on the brain; the electrical tape we cover the butyl tape is Super-88
..... Gordon Bok
post #17 of 17 Old 04-06-2009
I was wondering what the white stuff leaking out of your ears was...
butyl tape pegasus1457 Gear & Maintenance 53 04-30-2009 05:58 PM
Rebedding toerail...butyl tape mess Finallybuyingaboat Gear & Maintenance 8 03-30-2009 01:36 PM
Butyl tape questions. baboon Gear & Maintenance 11 12-09-2008 10:10 PM
Three ways to fix dodger windows GoodOldBoat Gear & Maintenance 2 11-05-2008 05:37 PM
Butyl Tape fer hardware sealing fun! Skipper Joe Gear & Maintenance 10 04-18-2008 12:33 PM
