Old 04-07-2009
phibbard is on a distinguished road
Anchor Chain Cleaning
There was an anchor chain cleaning device invented by Michael H Golden
of Bellingham Washington in the 1990's. It was a simple device that
encorporated a plastic sleeve filled with plastic bristle brushes that
was notched and slipped over the anchor chain. There was a lead weight
to keep it submerged on the chain and a small nylon line was attached to
the top of it. As the anchor chain is retrieved the brushes scrub the
chain under water and remove the mud and sand. I had one of these and
unfortunately it became a member of Davey Jones locker. Does anyone
know of where I could procure one of these? Davis sold them years back
but they are now discontinued.
Patent# 5351359
Thanks,
Peter and Jan Hibbard
CSY37B "JAZZ" #006
Old 04-07-2009
Why don't you make one using schedule 80 PVC pipe. Take a 4" diameter piece about a foot long... drill two holes in it, one at each end for a shackle, cut a slot in it and add three brushes to the interior. Add a weight to one shackle, a line to the other...
Probably cost you all of $25 to make, including the shackles and line.
Old 04-07-2009
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Davis Instruments manufactured and sold a similar device for awhile. It worked reasonably well but didn't sell all that well and was discontinued. You can make a fairly good facsimilie by arranging two scrub brushs with short stiff bristles fact-to-face, connected on one side by a "piano hinge" and on the other with a cam-lock. This can be locked over the chain forward of the bow roller and weighed down with a 2# dive weight with a line to the pulpit to keep it near the surface. It works, but not as well as a wash-down.
FWIW...
s/v HyLyte
Spring Hull Cleaning Tom Wood Gear and Maintenance Articles 0 04-05-2004 08:00 PM
Sail Care and Cleaning Kathy Barron Gear and Maintenance Articles 0 10-20-2003 08:00 PM
Cleaning Sails Sue & Larry Gear and Maintenance Articles 0 06-09-2002 08:00 PM
Cleaning Fiberglass Hulls and Decks Sue & Larry Gear and Maintenance Articles 0 03-07-2002 07:00 PM
Cleaning Fiberglass Hulls and Decks Sue & Larry Her Sailnet Articles 0 03-07-2002 07:00 PM
