Lift Keel Appears to be Missing - Page 2 - SailNet Community
post #11 of 13 Old 04-07-2009
If you do a search on Google for a cal 24 there is a link to cal boats/Jenson Marine. there is a line drawing of an earlier version with a swing keel.
Sorry I cannot post the link, not enough posts yet.
Cheers
Steve W
Halifax NS
SteveWho is offline
post #12 of 13 Old 04-07-2009
Of course, if you get down on the ground with a flashlight and look up into the slot, you should be able to see the swing keel if it is there.
sailingdog is offline
post #13 of 13 Old 04-07-2009
Somewhere along the line it should be mentioned that a centerboard can be a good thing but it is also "moving parts located under the water line".
If it IS in there, you should find a way to support the boat that also allows you to drop the keel/board while it is in the yard. You'll need to clean out the slot that it resides in, check the lifting wire (synthetic line is a good alternative these days for some), and use bottom paint in there as well as on the board, to discourage more critters from growing and jamming your board up in the slot.
hellosailor is offline
Southerly 101 PracticalSailor Buying a Boat Articles 8 06-14-2011 07:40 AM
Cape Fear 38 -- Lost Keel Fatality Investigation JohnRPollard Sailboat Design and Construction 296 02-09-2011 09:51 AM
Best type of keel halsmithjr Seamanship & Navigation 10 07-01-2006 12:18 PM
Keel Bolt Repairs Don Casey Gear and Maintenance Articles 0 11-10-2003 07:00 PM
Short Keel vs Normal SEAJM General Discussion (sailing related) 1 03-12-2003 02:13 AM
