04-09-2009
The view is directly proportional to the potential for splatting the human body... the higher the splat potential*, the higher it looks... that's why the same distance over water looks far less than that same distance above pointy rocks.
* Often referred to as the pucker factor, due to the way it causes certain orifices to pucker up tighter...
Originally Posted by MJBrown
Why is it that it looks higher from the top down, than the bottom up?
