Old 04-09-2009
nk235's Avatar
nk235 is on a distinguished road
Lost rigging while sailing
2 days ago I was responding to some posts on here about rigging and when to replace and even though mine is original it looks to be in excellent condition, etc., etc.....Well today I was moving my boat from its winter berth to be hauled out for a bottom job at a marina a few miles away. Raised the main, had a nice breeze, gorgeous day. Then as I was unfurling the jib I felt something weird and then as the sail was out noticed the backstay was very slack...turned out the furler which on my older hyde unit is the one and only headstay, parted from the mast! The halyard was the only thing holding everything up. Luckily we dropped all sail and continued under power to the marina where I had the boat hauled and a rigger take a look at everyting. Now I am going to have a new headstay and furler put on and am most likely going to replace everything.
Just thought it was ironic how not only 2 days ago I was asking about replacing my rigging...received my answer in a different way!
Morgan 323
Old 04-09-2009
Sea Slacker
brak is on a distinguished road
yep, unfortunately as my experience had shown - brand new stuff is not immune from this. I had a just installed new forestay part on a very first day out (and not even under sail)
Old 04-09-2009
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
Glad it turned out ok.
The other thread is called: rig inspection diy or hire someone.
It wouldn't let me post the link because INSIDE THE LINK ADDRESS, it parsed the word rig <-- like it just did there.
Old 04-10-2009
Maine Sail's Avatar
When we bought our current boat it had a Hyde Stream Stay. I never even let her in the water with it....she got a new Harken & standing rigging before I even launched... Rigging is cheap compared to a new spar..
______
-Maine Sail / CS-36T
Old 04-10-2009
hellosailor's Avatar
nk, new headstay, yes, but new furler? Might be overkill, bear in mind that depending on what furler you have, a set of new bearings, a couple of new pins, a new line, and you may have a perfectly effective total overhaul. The loads and failure modes (and potential consequences) aren't at all the same.
Long time ago, I got out to a boat I was crewing on early. Started cleaning up small stuff mainly to stay awake, and cleaned the wrapping off the forestay turnbuckle, only to find the pin holding it all together was just barely hanging in, cotter pin long gone. If I hadn't been early and bored, we might very well have lost the stick that day, or shortly after.
So as Dubyah, Chairman Mao, and a variety of other characters have said over the centuries, "Trust but verify". Just don't let it panic you into throwing out perfectly good gear simply because it is old.
Old 04-10-2009
Maine Sail's Avatar
The Hyde furlers did not use a head stay. The stainless swivels were basically glued/epoxied/bonded onto a solid aluminum extrusion that acted as the head stay. Some of these Hyde's had the swivels come unglued from the extrusion.
______
Old 04-10-2009
celenoglu's Avatar
celenoglu is on a distinguished road
Head stay failures are the most common ones. The general point is from the top of the mast. This is due to furlers. Te oscilation of the furler causes premature breaking of the head stay. changing only the head stay in this condition is enough. The other stays are generally safe to use.
Old 04-10-2009
Bene—
Use TINYURL.COM to convert the links to a form that the keyword autolinking engine won't screw up.
Old 04-10-2009
Relying on an adhesive for something that is cycling under tension isn't all that great a design idea... what exactly were they thinking???
Old 04-10-2009
tommays's Avatar
They were thinking the same thing that all the people glueing carbon tubes into bike frames were at the time
Or Peugeot with the Pechiney frames that fell apart
""The frames tubes, seat, top, down and all 4 stays were joined to the lugs without a bonding agent or without welds. Peugeot called it the 'Pechiney' process. Quote form the catalogue "The assembly of the frame is performed with a special, patented technique that fits the tubes into the lugs without the use of any bonding process such as welding or glue."
Which is to say they were NOT thinking
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Learning to sail, My initial observations of Sailing Associations donhaller Learning to Sail 2 04-18-2009 04:47 PM
The Year in Sailing (2001) SailNet Learning to Sail Articles 0 12-30-2001 07:00 PM
Off-Season Sailing Seminars Dobbs Davis Learning to Sail Articles 0 12-05-2001 07:00 PM
How Other Sailors Learned Mark Matthews Learning to Sail Articles 0 08-31-2001 08:00 PM
