yanmar wont start((winterized)) - Page 2 - SailNet Community
post #11 of 18 Old 04-10-2009
Cod,
Is the engine fresh water cooled? And are there any glow plugs. If fresh water cooled and no glow plugs the model # is 2GM20F. With that engine you will have trouble starting it if it's cold outside.
denby is offline
post #12 of 18 Old 04-10-2009
Irrationally Exuberant
It's definitely worth getting yourself a book on the engine, codmander--a Yanmar service manual, even a third-party one like the Clymer manual, will save you a bunch of guessing.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #13 of 18 Old 04-10-2009
Cod,
Check this out.
Yanmar 2GM & Related Links
denby is offline
post #14 of 18 Old 04-10-2009 Thread Starter
thanks defintly air in fuel did get it to start for a few secounds
codmander is offline
post #15 of 18 Old 04-10-2009 Thread Starter
Originally Posted by denby View Post
Cod,
Check this out.
thank you
post #16 of 18 Old 04-16-2009 Thread Starter
geeez had to back 5 pages ((busy here)) anyhow thanks got it running and it runs quite awesome heck even found the dip stick along with 6000 other things anyhow thanks for the info found it quite handy ...............................on to problem 2...
post #17 of 18 Old 04-16-2009
ancient mariner
captbillc's Avatar
codmander---- here is a tip for starting a cold engine that is getting fuel, but just puts out white smoke when you crank it. you have to heat the incoming air. remove the air cleaner, take a propane torch and put the flame into the intake manifold while the engine is cranking. the extra heat in the air raises the final compression temperature enough so the fuel will fire. some truck engines had a burner in the intake manifold to do this, & some use electric heating coils to do this
Liberals are people who care about others. Freethinkers are not constrained by the myths of religion.
captbillc is offline
post #18 of 18 Old 04-16-2009 Thread Starter
hmm interesting do have propane on board... hopefully wont need to do that fires every time now...but a great tip thanks .new to deisals as you probly noticed ............ now to attack that ugly wiring gotta clean the bildge first tho...
Need help YANMAR engine mount Giulietta Gear & Maintenance 20 04-15-2010 01:15 PM
Yanmar Problem Solved... Warren M. Gear & Maintenance 1 09-01-2008 09:39 PM
Yanmar Engine Mount Specifications HenryTully Gear & Maintenance 4 06-27-2008 10:20 AM
Yanmar 3gmd Question nk235 Gear & Maintenance 4 03-12-2008 04:48 PM
ATF or SAE ? Yanmar 4JH2E / Trans: KM4A TAK Gear & Maintenance 4 11-05-2007 10:34 PM
