Old 04-10-2009
jaschrumpf's Avatar
1975 Newport 28
jaschrumpf is on a distinguished road
Lost a wire somehow
Here's a good one: I was cleaning up the terminals in my 12v fused panel and putting good ring or female clip terminals on all the leads that were just wires wrapped around a screw. Somehow in the process I've lost my steaming light wire!
I've reconnected every wire I had there previously, but now for some reason my steaming light doesn't come on. I know it's not just a burned out bulb, because I've accounted for every wire coming to the panel and all the fixtures work -- it's just that I no longer seem to have a wire that connects the steaming light!
If anyone has any knowledge of a Capitol Yachts Newport 28 wiring harness and knows what the steaming light wire should look like, I'd love to hear from them. I'll be spending part of my weekend crawling behind the panel to see if a wire's gotten away and hidden itself!!!
S/V Free Spirit
Monrovia, MD
Old 04-10-2009
boatpoker's Avatar
surveyor
boatpoker is on a distinguished road
Sorry tp be the bearer pf bad news but you are dreaming if you think there was ever a "wiring harness" or that any two boats were wired the same or that they followed ABYC colour codes. You are going to have to trace it from the base of the mast.
Dirt People Scare me
Old 04-10-2009
Even most sister ships aren't wired exactly the same.
Old 04-10-2009
jaschrumpf's Avatar
1975 Newport 28
Eh, I thought as much. Still, that bebuggered wire was there not just a week ago, so it's still got to be around somewhere.
The idea that haunts me is that among the PO wiring abortions I discovered were several splices into wires that made no apparent sense, and that I now wonder if they were some kind of deranged workaround to make the lights come on.
Well, I guess I'll figure it all out, given enough time.
S/V Free Spirit
Monrovia, MD
Old 04-10-2009
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
Look into the splices you mentioned. If your were tinkering aound then odds may be you dislocated one of the wires in the splice that corresponds to your steaming light. You st5ated you had all other things accounted for. If I was in your position - I would mount terminal strips or bus bars (which ever makes sense for you), and run the main wire from the fuse / circuit panel - and attach the wires in the splices with individual connectors to the strips / buses...Hopefully that makes sense - anytime you start a re-wire project its more complex than it was originally intended...
-- Jody
S/V "
1983, Barberis Show 38! or
Old 04-10-2009
justified is on a distinguished road
jaschrumpf
I have a 78 newport 28 and I don't now if it will help I do have the original manuals with wiring diagrams I would be able to copy and email them on Monday if you think they might be a help. Also when I rewired my mast two yrs ago I now that at the mast it was just a three wire 2 hot and a groung goiing to the steaming light and the anchor light.
PM me or email pcarey zero two at snet dot net
Peter
"Justified"
Old 04-11-2009
nickmerc's Avatar
nickmerc is on a distinguished road
It sounds like you may want to consider rewiring the boat. If you just replace the wires and not the panel, lights or other fixtures, it will not be too expensive. This way you know exactly what each wire does and where it goes. You should also draw a schematic for future reference.
________
Brittnii_Lynn
Old 04-11-2009
timebandit's Avatar
timebandit is on a distinguished road
Have you tried turning everything on to see if the missing wire is attached to something else?
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
Old 04-12-2009
jaschrumpf's Avatar
1975 Newport 28
Yeah, I did that one. No go. But I think the clue is in the above post from the '78 Newport 28 owner who said the wire from the mast is a two-hot, one ground lead. I do remember seeing an abominable splice into the wire that controls the mast light (which I took out), so I'll be taking a closer look at that next time I'm down at the boat.
S/V Free Spirit
Monrovia, MD
Offshore Log: Check Your Lifelines, Save Your Life PracticalSailor Gear and Maintenance Articles 3 04-26-2007 12:23 PM
Keeping Wiring Woes at Bay Chris Brignoli Gear and Maintenance Articles 0 01-26-2004 07:00 PM
Electrical Work Rules Don Casey Gear and Maintenance Articles 0 07-16-2000 08:00 PM
