Old 04-11-2009
donhaller's Avatar
donhaller is on a distinguished road
Minwax Spar Eurethane
I have searched on this with no results found, but I'm sure someone must have asked this question a million times.
I bought a quart of Minwax Helmsman Spar Eurethane to reseal some interior teak panels that fit into the bilge cutouts in my cabin floor. It has done a real nice job on these pieces and I was wondering how it will hold up on trim up above. I don't have much wood trim on deck and in the cockpit, mostly just the tiller handle and the companionway hatch slats and coaming.
The can claims UV and outdoor protection; does anyone have experience with this stuff used on exterior trim?
Chesapeake Beach, MD
C&C 25 MKI, Hull No. 039
Old 04-11-2009
Ulladh is on a distinguished road
I have used minwax spar varnish on hatch board and tiller over a minwax stain.
I get about two years between light sand and recoat of hatch board, but the minwax does not hold up on the tiller, probably to mutch abrasion from use.
Old 04-11-2009
JimMcGee's Avatar
JimMcGee is on a distinguished road
It won't hold up nearly as well as something like Interlux Goldspar.
95 C30 Island Time
‘Not all who wander are lost.' ~ JRR Tolkien
Old 04-13-2009
captainmurph is on a distinguished road
The minwax polyurethane is good for interiors and will hold up well. But, anything that is subject to UV rays won't last more than two seasons (less in high sun areas) without a good spar varnish.
Varnish is simply the best when it comes to sun exposure.
I found this out the hard way after using this product on handholds and tiller in past boats.
Murph
Old 04-13-2009
donhaller's Avatar
Murph
Thanks Murph et al.
I will plan to use it only inside the cabin areas and get some good Spar Varnish for the exterior elements.
Old 04-13-2009
nightowle's Avatar
nightowle is on a distinguished road
also used it on my tiller and deck handrails with bad results
________
S/V Don't Panic!
O'Day 27
Seattle, WA
“Navigare necesse est, vivere non est necesse” To Sail is vital, to live is not.
Old 04-13-2009
Ornery Cuss
riphonda is on a distinguished road
Spar Urethane...
I say that the stuff is easy to work with, easy on the wallet and works good on interiors as stated above. I will however say that its not truly "marine" as the name implies... Even minwax suggests that you dont use this stuff on exterior boat stuff in the marine environment. Perhaps they should change the name. (But it got you, me and the rest of us to fall for it) I coated up my carolina skiff mahogany with it and it lasted almost the whole season here up in new england but I probably needed more like four coats instead of two. Just not enough time. Heres what it looked like when done, stuff is convincing after applied and for the price served me well but im starting to get tired of all the sanding and doing it twice instead of paying up front. A lesson i've learned many times.
Skiff:
1976 Sabre 28
"If at first you don't succeed, destroy all evidence that you tried...
Upgrading Spars Tom Wood Gear and Maintenance Articles 0 12-01-2003 07:00 PM
Offseason Spar Care SailNet Gear and Maintenance Articles 0 09-30-2002 08:00 PM
Stepping the Spar Tom Wood Gear and Maintenance Articles 0 09-15-2002 08:00 PM
Spar Corrosion Demystified Mark Matthews Gear and Maintenance Articles 0 07-01-2002 08:00 PM
Spar Speculation Sue & Larry Gear and Maintenance Articles 0 07-03-2001 08:00 PM
