Building a water tank - Page 2 - SailNet Community
post #11 of 13 Old 04-13-2009
Did you use CeRAM-Kote 54 for the inner epoxy lining???
Originally Posted by genieskip View Post
It is not built out of plastic. It is 1/2" marine plywood covered on both sides with fiberglass cloth & layers of epoxy, then covered on the inside with a special food grade epoxy. And yes, there are baffles. No space is bigger than 30", same as the fuel tank requirement for baffles.
I'll take some pictures as the job progresses and post them later.
sailingdog is offline
post #12 of 13 Old 04-14-2009
Valiente's Avatar
Good to hear. I'm having to remove two 100 gallon SS tanks this year because I found out in a small gale that they were NOT baffled (BOOM! BOOM!)
I mentioned it purely because not all self-built projects are well-researched, even with all good intentions.
Can't sleep? Read my countdown to voyaging blog @
Valiente is offline
post #13 of 13 Old 04-14-2009
bljones's Avatar
I just re-read the article in GOB. The article does a pretty good job of detailing construction and epoxy choices, but there is no mention at all of caulking. Your dog's appetite has done you no irrepairable harm.
bljones is offline
cleaning aluminum water tank rbtpfe9 Gear & Maintenance 18 12-27-2010 12:31 PM
Contaminated Water Tank mtmd Gear & Maintenance 17 10-01-2008 07:41 AM
Repairing an integral fiberglass water tank welshwind Gear & Maintenance 12 07-11-2007 01:46 PM
Checking Water Quality & Cleaning Headliner dougshipl Gear & Maintenance 6 05-23-2007 03:17 AM
Building a head tank Irwin32 Gear & Maintenance 6 11-05-2006 01:24 AM
