04-13-2009
Use this stuff: LINK
Basically, any NSF rated sealant should work. If you did a search for NSF food grade sealant, it'd turn up a lot of solutions... The NSF rating is the key thing for potable water systems.
The tank isn't going to flex... he's built it from fiberglass with NSF grade epoxy by the sounds of it... the OP is looking for a sealant that he can use to seal where the tank fittings enter the tank... the NSF silicone sealant I linked to is designed for pretty much that kind of task.
Originally Posted by US27inKS
Salt water aquarium fish are VERY sensitive critters. Corals die for almost no reason at all. You can believe that if it's safe for a reef tank, it's safe for you.
The only thing I would be concerned about is the strength of the adhesive. Aquarium adhesive is designed to seal two pieces of precision fit glass together. No gaps or irregularity. No flexing either. The two part epoxy is great for something that's never going to flex as well. I doubt either will be a suitable sealant for this project.
I know you're already into this project and it's too late now, but why didn't you go with a flexible bladder?
