wnd transducer cable - SailNet Community
post #1 of 4 Old 04-13-2009 Thread Starter
Wind transducer cable
I'm going to buy a new or second hand(?) wind instrument, possible a Raymarine ST60.
At the moment my mast is down, so it's easy to run a new cable, but, since I did not made the desicion yet what brand, and possible offers at Ebay, I like to run a "custom" cable and connect it later to the wind transducer (and instrument).
I know Raymarine uses a 5 wire + screen. Can I use any good quality cable, and, is it possible to connect it to the transducer? What about plugs, etc.?
I know Tacktick will be easy, but $$$
Thanks for suggestions!
gzol is offline
post #2 of 4 Old 04-13-2009
celenoglu's Avatar
You need to connect or solder the cables to the transducer. That means a trip to the mast head and stay there for a long period. Instead of using a cable, try a line as a lead. You can move the cable needed inside the mast ithe line after you buy the equipment.
celenoglu is offline
post #3 of 4 Old 04-13-2009
Actually, you need to connect the wires to the transducer mount, which is a six-pin socketed plug. Usually, the mount has the wiring attached to it, since it is supposed to come pre-wired. The bottom end of the ST60 transducer is a set of pins in a screw collar that plugs into the transducer mount and screws tight.
You can see the Raymarine ST60 wind transducer mount with protective cap in this photo, it is the dark grey plastic piece mounted to the top of the mast, beside the masthead crane.
If the second-hand instrument doesn't come with the mount pre-wired, you really should buy a new mount that is wired. The mast head is no place for additional wiring connections, since wiring problems are the primary cause of wind instrument issues IMHO—which is why I upgraded to the TackTick gear.
The Raymarine wind transducer mount is pre-wired with 100' of wire, which should be enough for most boats up to about 40' LOA or so. You will need to get a special through-deck connector, unless you plan on running the wire straight through to the instrument—which I don't recommend, since you won't be able to unstep the mast in that case. You can use either a terminal strip and a cable clam to get the cable through the cabintop/deck or you can use a six-pin pass-thru-connector. One connector I've used with good success is a weatherproof RJ-45 connector and terminated the cable coming down the mast using a weather proof RJ 45 plug.
sailingdog is offline
post #4 of 4 Old 04-13-2009 Thread Starter
Guys,....
Thank you, I should have tought about aleading line.... How stupid....
gzol is offline
Installing an anchor windlass GoodOldBoat Good Old Boat 9 05-23-2015 06:53 PM
Installing an anchor windlass GoodOldBoat Good Old Boat 2 06-05-2013 11:10 PM
