headsail terminology questions (heavy/light) - Page 2 - SailNet Community
post #11 of 26 Old 04-13-2009
AdamLein's Avatar
Originally Posted by tigerregis View Post
When I raced on big boats, light and heavy had to do with apparent wind speed. The light was good to 10-12 after that the 1. The boat carried 28 sails and had something for everything, including trysail and blooper. If you've ever gone 14 knots under a blast reacher and two reefs, you know what a suit is.
Does anyone use bloopers nowadays? I've only seen them in photos on the covers of sailing books from the 80s. One of my goals in life is to fly as many sails at once as possible.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #12 of 26 Old 04-13-2009
blt2ski's Avatar
Not sure what a blooper is, and how used. But I did pickup a 130'ish drifter/reacher a month ago, worked really well in some light up to 6 knot winds in a race Ap 4th. gained us about .5-1 knot vs the 155 carbon. Anything over that, the 155 gained us an additional knot.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #13 of 26 Old 04-14-2009
Valiente's Avatar
Bloopers, tallboys, reachers, bananas, and the one I've actually used, my genoa staysail with wire luff that tacks to the rail...they all have gone to die in the rafters of my garage.
Some of them emerge recut as one-season, sail 'em 'til they shred foresails. Others get to be paint or plaster tarps.
Can't sleep? Read my countdown to voyaging blog @
Valiente is offline
post #14 of 26 Old 04-14-2009
baDumbumbum
bobmcgov's Avatar
Blooper thus:
It is (was, thank God) a low-slung mini-spi meant to counteract IOR boats' habit of rounding up violently under symmetrical kite alone. IIRC, it was counted as a jib and so also increased downwind sail area without a penalty hit.
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
post #15 of 26 Old 04-14-2009
Ex Member
Originally Posted by bobmcgov View Post
Blooper thus:
Trimmed by raising and lowering the halyard.
Now let us never speak of this abomination again
ste27 is offline
post #16 of 26 Old 04-14-2009
The general theory is that for a racing boat that has a fixed max headsail dimension, a "Light" No. 1 would have a fuller draft and lighter material than the "Heavy" No. 1. The "Light" No. 1 would be a more powerful sail, fuller draft, yet not as high a pointing sail, enabling you to build speed and power through the chop that would slow a boat in light winds. In practice, the "Light" would go up to about 7 - 9 kts AWS and the "Heavy" would take it from there, to the No. 2's range, typically in the low to mid teens AWS. There really is no such thing as a "Light" No. 2 as that sail is optomized for higher wind speeds, and the next gear shift would be to the No. 3.
In addition, while feasable, you could have a "Light" mainsail and a "Heavy" mainsail, both with optomized drafts and materials for their expected wind ranges. I have sailed on boats, years ago, that had them, but sail count limits make them useless.
In regards to the comments about "Bloopers" helping to aleviate the IOR boats unstable downwind tendancies, I don't think so much... The Blooper was a VERY unstable sail, and never used in the highwind conditions that would create the combination of factors that would facilitate the famous IOR "Death Roll" or broach. They were exclusively used in light to moderate wind conditions, dead down wind running, and the proper technique actually had you LOWER the mainsail to gain the greatest benifits. Glad to see then go!
With the introduction of modern fractional rigged high performance boats, the mainsail was no longer relegated to a secondary role. The need for "Light" and "Heavy" headsails of the same size became secondary to the proper trim of the now larger and more powerful mainsails.
Silmaril is offline
post #17 of 26 Old 04-14-2009
tommays's Avatar
Are light # 1 is good for 9 knots and the heavy #1 about 20
The light #1 3DL requires repiars EVERY race because the film is so thing it cant take wacking anything during a tack SO we really try not to use it
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #18 of 26 Old 04-14-2009
Back in my racing days we flew a blooper on a Kiwi 30. Under the right conditions it was really fast dead down wind. Bloopin' helped us get many 1st place finishes. Most boat are designed to sail jibe angles downwind now so you don't see them much.
SteveInMD is offline
post #19 of 26 Old 04-14-2009
AdamLein's Avatar
Originally Posted by Valiente View Post
Some ... get to be paint or plaster tarps.
AdamLein is offline
post #20 of 26 Old 04-14-2009
Well I have one for you. My boat has a spinnaker staysail which I have and have flown a couple of times on our 1967 Chris Craft Apache sloop (S&S). It basically throws a little more wind into the spinnaker.
Moe
mgiguere is offline
Headsail sheet - general length questions britcoal Gear & Maintenance 6 08-02-2007 03:43 PM
terminology question(s)... Kernix General Discussion (sailing related) 9 03-07-2007 03:40 PM
Headsail Reefing Basics Brian Hancock Seamanship Articles 0 08-05-2004 08:00 PM
Headsail Reefing Basics Brian Hancock Gear and Maintenance Articles 0 08-05-2004 08:00 PM
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 08:00 PM
