04-14-2009
Why would you want to do that when there are a lot of other ways to raise the mainsail that are far less expensive and more reliable.
For instance, adding a block to the top of the mainsail headboard and turning the main halyard into a two-part purchase, while requiring a longer main halyard, is a simple and very effective way to increase leverage.
Adding a line clutch to the mast above the winch would allow you to jump the halyard more effectively, and in many cases eliminate the need for an electric winch.
