Rudder Bearing Info - J/28 - Page 2 - SailNet Community
post #11 of 34 Old 04-14-2009 Thread Starter
Originally Posted by Paul_L View Post
Do other J/28's have the zerk fittings? I'm guessing these were an after thought. It looks like you have a roller upper bearing, maybe a Harken on the post. The stainless sleeve you have on the post looks the same as the one that is used with lower roller bearings. Is it possible that the boat was built with a Harken lower bearing and that a previous owner wanted to to do a cheaper replacement and added the Delrin bearing and zerk fittings?
Paul L
Paul, good questions. I haven't been able to look at another 28 to confirm.
The upper bearing consists of a stainless steel sleeve bonded to the rudderpost; it rides inside of a bronze tube / top plate bolted to the deck. There is another Zerk on the top bearing tube. I'm sure it is not a roller bearing.
I have no way of telling for sure, but I think the condition of the lower bearing probably makes it original. Other J's of similar vintage have the same 'holes', but instead of Zerks, they are set screws. I think the size of my boat probably doesn't create the loads required for a roller bearing...hence the Delrin setup.
Jason
jason3317 is offline
post #12 of 34 Old 04-14-2009 Thread Starter
Originally Posted by tommays View Post
If you google "harken rudder bearing'
Jefa, imported by PYI comes up a lot as making copys of them
J40 Rudder Bearings
Yes, Harken got out of the rudder bearing business in the early to mid-90s. The circulated around the industry the drawings / specs for the bearings. There is even a bearing cross-reference document for J/Boats - Harken. The J/28 is not one of the models listed on that doc - the smallest is the J/32.
I am pretty sure I could use a Jefa roller bearing for a replacement, but this is likey a higher cost $$ option. I haven't ruled it out 100%. If I was planning
to keep the boat another 20 years...then I would consider it more strongly.
post #13 of 34 Old 04-14-2009
Jason,
Wow what a coinsidence. I'm pulling the rudder on my J28 tomorrow for the very same reason. I have hull #11 and sail in narragansett bay. I also have quite a bit of experiance making parts out of delron, it's very good stuff.
I'll keep up with you and let you know what I'm doing.
John
jfws88@cox.net
jfdubu is offline
post #14 of 34 Old 04-14-2009 Thread Starter
Originally Posted by jfdubu View Post
Jason,
John
jfws88@cox.net
John, sound good. Please post pictures for comparison if possible. Let us know how it goes.
Jason
post #15 of 34 Old 04-16-2009
Well Jason, I wasn't as lucky as you. After removing the first two bolt of the quadrent I thought I was fat, dum and happy. The second two turned me in just fat and dum.
So far I've turned the two hex bolts into round bolts with an impact gun, I've cut the heads off with my dremal and tried screw drivers and wedges and it will not split on one side. I'll be cutting it off tonight.
I can tell you I don't have setscrews or zerk fitting in either the top or bottm bearings
John
jfdubu is offline
post #16 of 34 Old 04-20-2009 Thread Starter
John, any update on your progress? I also sent you an email.
post #17 of 34 Old 04-20-2009
Hi Jason,
Well I did finally get the damn rudder out of the boat. I had to cut two of the bolts out of the quadrent and I still have got one of the bolts out of the holes.
Any way it's out. I havn't taken any pictures as my daughter took the camera to college with her. But with the execption of the color (mines red) it looks identical to yours. I have the same discolored areas and the same delron bearing. I havn't decided if I'm going to take the bearing out. Mine looks like it's glassed in and may just stay that way. I was surprised at how heavy the rudder is. I'm guessing 100+ lbs, is yours that heavy?
When your's came out did it slide out of the top sleeve or did you have to fight it like it did.
BTW, no grease fittings anywhere on my bearings.
Nice new J28 site hey?
John
jfdubu is offline
post #18 of 34 Old 04-20-2009 Thread Starter
John, thanks for the update. It took 2 to handle the rudder as it came out so, yes, ~100lbs.
The delrin sleeve is definitely glassed or otherwise retained into the hull, either way the only method of getting it out will involve a big saw.
I pulled the bolt that retains the top stainless sleeve and serves as a rudder stop; it came out still attached to the shaft.
Given you have the same wear patterns on the Delin, I am questioning the value of the grease fittings, and grease in general. It's either to cushion the wear on the delrin, or displace seawater to mitigate the stainless corrosion, I suppose. Doesn't seem like it made a difference.
The leading idea (today) from the yard is to build up the derin sleeve with a carbon/graphite/epoxy fillet mix, then hone the surface back to oem tolerances. The only concern I have here is maintaining / creating proper bearing backlash.
If we decide to cut the old delrin out, then I have the option of replacing the delrin with the same material, or switching out to a roller bearing. These two solutions are pricy, I think.
Everyone else...feel free to chime in with comments.
post #19 of 34 Old 04-20-2009
>that heavy?
One thing worth doing while you have the rudder out is to put it on a saw horse with the bottom lower than the top and drill a couple of small holes near the lower end. See how much water comes out and for how long. A little is probably expected, alot is needs looking into. You can easily epoxy the holes latter.
Paul L
Paul_L is offline
post #20 of 34 Old 04-20-2009
Delrin is probably lower maintenance than roller bearings. The problem with using a graphite composite is that graphite can cause serious galvanic issues with aluminum, since it is more noble than the aluminum.
sailingdog is offline
James Baldwin's Pocket Bluewater Cruising Boat List sailingdog Cruising & Liveaboard Forum 14 09-16-2011 05:26 PM
Building a Rudder Newport 30 Armchairprotest Gear & Maintenance 5 04-07-2009 01:11 PM
Emergency Steering John Kretschmer Seamanship Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Gear and Maintenance Articles 0 03-08-2002 07:00 PM
Emergency Steering John Kretschmer Cruising Articles 0 03-08-2002 07:00 PM
