Frozen Prop - Page 2 - SailNet Community
post #11 of 17 Old 04-15-2009
Lynger1
Hi just calm down
having had that problem with some other boats
just get small angle grinder with steel cutting blade grind/cut lengthwise with the shaft go just deep that you don't hit the shaft
do the same on other side and just grind/cut to the shaft try to avoid marking shaft
This Will fix it Will take you around 1/2 hour
Done
lynger1 is offline
post #12 of 17 Old 04-15-2009
Contrary to some, I believe it is potentially damaging to use any kind of hammer and definitely don't "bang the hell out of it with a sledge" as that can cause damage to the transmission. I've seen yard jockeys do this often and it has always resulted in some collateral damage to the shaft, bearings or transmission which they don't care about or even acknowledge as it just means more money for them in additional avoidable work.
Heat and the proper puller is all that is needed.
k1vsk is offline
post #13 of 17 Old 04-15-2009
No hammering on the prop or shaft... bad idea... definitely may cause damage to the transmission...
sailingdog is offline
post #14 of 17 Old 04-15-2009
I don't discuss my member
Fstbttms's Avatar
Shock and vibration are part of what makes prop pullers work. Most even have a flattened spot on the tool that is a "hammering pad", if you will. They are designed to be beat on. Of course you don't bang on the prop or shaft themselves. I'd wager that I've pulled more props than anybody else on this board, all of them using the technique I've described. Never damaged anything doing it, transmissions included.
It is a rare prop that just comes right off when you apply the puller, as the OP is discovering.
Fstbttms is offline
post #15 of 17 Old 04-15-2009
A hydraulic puller is another option for the really stubborn ones, but still works better if you load it up and give the end a smack. Protect against the prop/puller assembly flying off by keeping the nut on the shaft.
Faster is online now
post #16 of 17 Old 04-15-2009
I had the same problem removing my prop in the winter.
I finally needed to use the combination of a suitable prop puller (I needed to modify it so that it didn't damage the prop hub), penetrating oil (PB Blaster in this case), and heat from a propane torch.
I had no luck with any subset of the above and was convinced that it was not coming off. With the above it came right off.
C&C 44
Kingston/Lake Ontario
jonb is offline
post #17 of 17 Old 04-15-2009 Thread Starter
Well went down after work for another shot at the evil prop. Left it last night with the wheel puller attached and a load on it. Got down and started lightly heating it...kept my hand on the shaft to make sure did not get too hot. After about 3 minutes heating it all over it suddenly popped loose. So the dragon is slayed. On to putting a new prop on and get her in the water. Thanks for all the advice and help. Really appreciate it.
Thisisus
Islander 32
Mobile AL
thisisus is offline
Switching to a Three Blade Prop Redfish Pacific Seacraft 6 03-31-2009 10:13 PM
Seafarer 26' prop shaft replacement jkimberly Gear & Maintenance 5 02-17-2009 12:04 PM
Folding Propeller Problems slj145c Gear & Maintenance 4 05-21-2008 09:39 AM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 08:00 PM
Choosing a Prop Sue & Larry Gear and Maintenance Articles 0 12-24-2001 08:00 PM
