Old 04-14-2009
thisisus is on a distinguished road
Frozen Prop
Trying to remove the folding prop off the shaft to replace with a fixed one. Any suggestions on ways to free a stubborn prop. Trying to avoid pulling the whole shaft out since involves dropping the rudder (which also involves having the yard pick up the boat to take it off). Using a 3 part wheel puller and already broke a finger on one. No budge. Was thinking of heating it. Other option take a sawzall and try to slice in two sections. Any ideas appreciated. Should have known this haulout was going too good.
Thisisus
Islander 32
Mobile AL
Old 04-14-2009
boofus is on a distinguished road
Heat and puller...... Something hot like mapp of oxy-cet so you heat the prop fast, not the shaft and prop together. sorry to hear about the finger....pullers can be a pain to juggle and set. I would put some tension on the puller and with heat it should pop.....
Good luck
Old 04-14-2009
Heat is certainly an option, to be used with caution (for obvious reasons).. Another would be to load up the puller again, and give it a good hard smack on the puller screw head... the shock might break the prop free of the taper. Soak it overnight with penetrating oil too.
If you do try the hard tapping method, do not stand directly in line with the shaft/prop when you do. Even better, leave the nut halfway on - the space between the nut partially threaded on and the prop will be plenty break free on the taper.
1984 Fast/Nicholson 345
Old 04-14-2009
k1vsk will become famous soon enough
Heat and puller with mapp gas as previously noted. The only reason I reiterate it is to add this caution - make sure the nut is loosely on the shaft as, when the prop goes release, it will snap back into what/who ever is directly in it's path unless the nut is there to stop it.
Old 04-14-2009
Very good advice here...
Old 04-14-2009
So regular propane torch won't heat up quick enough? Guess that gas won't mix with a regular torch head. Have to see if I can locate one and give that a try. Left the wheel puller attached with a load on it when I left the yard tonight. Maybe I'll try to hit the end first and then go for the heat next. Appreciate the ideas.
Thisisus
Old 04-14-2009
scottyt is on a distinguished road
yes mapp gas works with a standard propane head
Old 04-15-2009
If propane is all you have on hand try it, but mapp is considerably hotter
Old 04-15-2009
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
A gear pullers is not the right tool for the job. Use a real prop puller. Tension it up, bang the hell out of it with a small sledge (the puller, not the prop!) and if the prop doesn't come loose, reposition it and try again. Pressure, persistence and patience are the keys. The prop will come off. BTW, using a torch should not be necessary.
"Clean bottoms are FastBottoms"
Old 04-15-2009
celenoglu's Avatar
celenoglu is on a distinguished road
Use a freezer spray, and use a hammer on the nut.
Switching to a Three Blade Prop Redfish Pacific Seacraft 6 03-31-2009 09:13 PM
Seafarer 26' prop shaft replacement jkimberly Gear & Maintenance 5 02-17-2009 11:04 AM
Folding Propeller Problems slj145c Gear & Maintenance 4 05-21-2008 08:39 AM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Choosing a Prop Sue & Larry Gear and Maintenance Articles 0 12-24-2001 07:00 PM
