Blogs
User Name
Old 10-30-2002
Huntress Huntress is offline
Huntress is on a distinguished road
Head problem
In the "dry-bowl" mode of my Jabsco manual head, when I depress the plunger,there seems to be some type of backpressure.... the plunger has resistance, followed by a "chattering" effect as the plunger is depressed...... does not happen in wet bowl mode.....any help?
Old 10-31-2002
tsenator tsenator is offline
tsenator is on a distinguished road
Head problem
Yeah, I think what is happening is that the lever for your "Wet/Dry" mechanism is not doing its job. That is very typical of the "cheap" heads.
You can try and manually hold the lever *all* the way over to the dry mode when you flush and see if the backpressure is releived. If so, then the mecahnism is a little screwed up. 2 Fixes. 1) Easiest. Purchase new Jabsco head from West marine when they are on sale ($95) and replace the whole thing. 2) unscrew the plunger mechanism and *carefully* try and reposition the lever mechanism to get it working....
good luck
Display Modes
vB code is On
What''s the best toilet (head) and... Myblueheaven Cruising 2 10-04-2003 09:52 AM
Head installation Irwin32 Gear & Maintenance 4 03-20-2003 12:23 PM
Rudder head corrosion aflanigan Gear & Maintenance 3 01-27-2003 01:01 AM
Control Head fix for Merriman Steering System tdp Gear & Maintenance 0 08-12-2002 05:07 AM
Head Problems bootsy1962 General Discussion (sailing related) 3 02-19-2002 07:26 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
