04-22-2009
The headsail sheets should make at least two wraps around the headsail when it is properly furled. This will greatly reduce the chances of it flogging, but the sheets also have to be cleated off properly—and using a self-tailing winch is not cleating them off properly, since the wind could possibly blow the line out of the self-tailer.
Originally Posted by montenido
Hi all, thanks for the additional information. To answer one question, I don't think that I had secured my headsail sheets back to the cabin. So the furling line was secured, but not the sheets. This must have allowed the sail to unwind a bit and flog itself to death. SD, good suggestion about the sail tie. I did actually have a bungee around the furled sail, but it was not up to the task. I will continue to wrap the sail tightly and secure the lines to the cockpit. That is more than I was doing before
I get my sail back this week sometime, I can't wait. There is quite a difference between the 110% that I am using now and the 150% that is being repaired. On the plus side, I have sailed four times in 1 1/2 weeks.
Thanks again for the great info.
Bill
