Old 04-15-2009
montenido's Avatar
montenido is on a distinguished road
Sail Repair Recommendations Needed
Hi all, I received about 5-6 frantic calls yesterday from my marina telling me that my furled headsail had come loose in the 35-50 MPH winds that were blowing. I was stuck at work for 24 hours so I tried to talk them through dropping the sail (unsuccessfully). After the fifth or sixth call I began to make arrangements to get relieved and go to the boat myself. When I got there last night the wind was still howling and the marina staff had winched the sheets tight back to the cockpit on both sides. So the sail was still flapping wildly and coming apart.
I was able to drop the sail and ball it up, so I threw it into my car and left. This morning I laid it out and surveyed the damage. From what I can tell all the rips are along seams and not in the fabric itself. So I went from pricing new sails to just needing to find a reputable sail shop in the Los Angeles area. Wow, lucky me!
So, anybody out there have a good sail loft that they use in the Marina Del Rey or Channel Islands/Ventura area?
Thanks in advance.
Bill
Odyssey, '79 CSY 44 Cutter
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
Old 04-15-2009
blt2ski's Avatar
You might try the San Diego Ullman loft, and see what Chuck can do there. I've bought some sails from him thru the Puget sound Ullman sub dealer network.
Also keep in mind, depending upon the damage, a new sail could be the better route yet still. This depends upon the how much to fix, vs how old your current sails are etc.
Marty
She drives me boat,
I drives me dinghy!
Old 04-15-2009
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
North Sails 3481 W. 5th Street, #100, Oxnard, CA 93030 USA 805-984-8100
Ullman Sails 3639 E. Harbor Blvd. #111 Ventura CA 93001 (805) 644-9579 or (800) 248-2892
Next time put a bolt through the locking hole in your furler drum when you leave the boat.
Old 04-15-2009
montenido's Avatar
Thanks, I spoke with someone at North Sails and I am going to give them a try. I don't think I have a locking hole in my drum. It's a pretty old set up.
Thanks again, Bill
Channel Islands, CA
Mark Twain
Old 04-16-2009
jarcher's Avatar
jarcher is on a distinguished road
I have not tried them yet, but many speak well of this place:
Sail Care for sail cleaning, sail repair, new sails, roller furlings and sailing equipment
You can ship them the sail.
Old 04-16-2009
TxLnghrn's Avatar
Ignoring Trolls in 2009
TxLnghrn is on a distinguished road
Second vote for Sail Care, They took a 22 year old sail and made it look brand new. $48/hr for repair work, should be well worth the cost of shipping to you.
Michael
S/V Anything Goes
1987 Pearson 31-2
Hull #15
Old 04-16-2009
alecs123's Avatar
alecs123 is on a distinguished road
I've sent twice (different sails) to SailCare. The first time I had no other option since I'm in Mexico and there aren't reputable lofts around here, the sail came like new and I mean like new, really.
the second time I sent my main to have the batten pockets redone and the result was the same.
Not cheap thouhg, I will send again any sail that needs repairs/cleaning.
Alecs123
Alejandro Viveros
Valle de Bravo, Mexico
Merit 25, #302. 1982
Flying Tern 14', 1968
Old 04-16-2009
Bill—
I highly recommend putting a sailtie around your roller furled headsail if you're going to be away from the boat for any significant period of time...or get a headsail sock. Either of these will prevent the sail from unfurling and flogging itself to pieces. The sock has the added advantage of protecting the sail from UV damage.
Old 04-16-2009
nk235's Avatar
nk235 is on a distinguished road
This may be a stupid question and in no way am I directing it at the OP as I feel your pain on the sail work (going through the same thing with my furler and rigging now myself)
But how exactly does the sail unfurl itself in high winds? When I roll up my sail I make sure to roll it up so that it has about 3-4 wraps around it with the sheets acting like a sail tie I guess. Also before I coil up the sheets in the cockpit I make sure they are sheeted off fairly tight to a cleat so there is no way they are going to ease up. Also I make sure the furling line is well secured to its own cleat the everything is rolled up tight and cleated off so it can't unwind.
I am just curious if this is what everyone else does/what you are suppossed to do and how the sail could come loose from that?
Thanks
Morgan 323
Old 04-16-2009
I do the same thing... but you have to remember to put a few extra turns on the furling drum so you can do this. Also, I highly recommend leaving a few wraps on the drum, since some of the drums can split if the loads get too high on it and there aren't at least a couple warps of the furling line on it.
The reason I put the sail ties on the sail is if the furling line breaks or comes loose... it prevents the sail from unfurling. It's a bit overkill for normal weather, but if I'm going to be leaving the boat for more than a few days or if heavy weather is expected, I'll do it. The sail tie will also go around the genoa sheets that are wrapped around the sail, so they can't come undone.
Thanks
Traveler question sohi07 Learning to Sail 11 10-21-2006 11:47 AM
Considering a New Mainsail Brian Hancock Gear and Maintenance Articles 0 04-29-2004 08:00 PM
Upgrading Your Mainsail System Sue & Larry Her Sailnet Articles 0 11-17-2002 07:00 PM
Racers' Sail Care Tips Dan Dickison Gear and Maintenance Articles 0 08-15-2001 08:00 PM
Sail Trim Steve Colgate Seamanship Articles 0 05-10-2000 08:00 PM
