Old 04-15-2009
tager's Avatar
tager is on a distinguished road
Chainplates
I have 2 double chainplates through the deck mounted to my bulkheads . They are 0.25" by 1.5" by 12" long.
The starboard one is bent, and both are suffering from crevice corrosion. I would like to replace them: what is the best chainplate material?
Here are my options:
Brass
Mild Steel followed by a galvanized coating
Stainless
These will be going on galvanized rig.
Old 04-15-2009
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Brass has no place on a boat save in bells, horns, light fixtures (perhaps), fancy work or buttons.
From an engineering view point, the best material is bronze which has more than adaquate strength and none of the problems that SS is subject to in the given application. As most don't care for the green look, however, 316 Stainless is often chosen although, if you rigging is galvanized, bronze might be accepteable. Galvanized mild steel won't last long enough to be worth the effort. Whatever your choice, if you had crevice corrosion in the existing chain plates, check your bulkheads to ensure you don't have rot there from water intrusion that needs repair before you install the new chain plates. Also, there is a good article in the current edition of Good Old Boat on how to build footing pads for chain plates that can help prevent water intrusion around the deck plates that you might want to look into. If I remember correctly, these should work on an Islander 24.
FWIW...
s/v HyLyte
Old 04-15-2009
You really should make the new ones out of 316L stainless steel. You should also work to prevent any water egress, since that is what caused the old ones to fail from crevice corrosion in the first place.
Old 04-17-2009
tager's Avatar
Well they haven't failed. Yet. I may go with bronze.
Chainplates Newport 30 MBesant Gear & Maintenance 6 01-22-2009 03:09 PM
Bedding chainplates - quick and dirty way brak Gear & Maintenance 21 05-12-2008 02:42 PM
Replacing Chainplates FullandBy Gear & Maintenance 3 02-09-2007 04:13 PM
Sealing Chainplates mikehoyt Gear & Maintenance 6 08-25-2003 07:26 AM
chainplates mary jewell Gear & Maintenance 1 10-25-2002 06:10 PM
