Old 04-15-2009
mepsnbarry is on a distinguished road
LED Navigation Lights (sidelights)
We need to replace our old bubble-style sidelights, and we want sealed LED units (not LED bulbs).
They're mounted horizontally on teak pads. It looks like the only nav lights with that mounting system are the cheaper ones -- Perko, Attwood -- designed for powerboats. Are they robust enough for offshore use?
If not, we'll have to figure out some way to mount vertical lights, like the Lopolights or Orca Green Marine ones. We both hate the reflections caused when they're mounted on the bow pulpit.
Has anyone had experience with this?
s/v Flutterby, Freedom 33
- limericks, essays, and photos by Meps 'n' Barry
- recipes for cooks at sea and on land
Old 04-15-2009
negrini is on a distinguished road
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
I found Perko sidelights robust enough, but the question should be if they're compliant for your boat model/size/use. In my oppinion, the pulpit reflection is a sure they're working properly, and more visible (for my boat model) ....
Nave Rara
Beneteau Oceanis 43
Old 04-15-2009
I think the AquaSignal 32 series would work for you.
Old 04-15-2009
montenido's Avatar
montenido is on a distinguished road
I have also been switching my boat over to LED bulbs, but I came across some info in "The Practical Mariner's Book Of Knowledge" concerning lights. It states that colored glass absorbs 85-90% of the light from a bulb, and it recommends that you use the brightest lights that your boat can power for Nav lights. I would imagine that using a colored LED bulb inside a clear lens might give you the brightest set up. Just food for thought.
Good luck, Bill
Odyssey, '79 CSY 44 Cutter
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
Old 04-15-2009
OsmundL's Avatar
OsmundL is on a distinguished road
The Lopolight 300-008 and -009 are horizontal mounts. Could they fit? The Lopolight is a glorious product if you can find a way.
LEDs afloat GoodOldBoat Gear and Maintenance Articles 18 12 Hours Ago 03:15 PM
Working With the Stars—Celestial Navigation Jim Sexton Seamanship Articles 0 05-06-2003 08:00 PM
Navigation Basics Jim Sexton Learning to Sail Articles 0 01-04-2002 07:00 PM
Navigation Basics Jim Sexton Seamanship Articles 0 01-04-2002 07:00 PM
Navigation Basics Jim Sexton Her Sailnet Articles 0 01-04-2002 07:00 PM
