Manual Bilge Pump - Page 2 - SailNet Community
post #11 of 14 Old 04-17-2009
ASA and PSIA Instructor
The pickup for the manual pump should be in the lowest part of the bilge. If you have a hose running up under the shower stump, then it should serve to pump out that stump...not the best arrangement. I'd rather have the electric on the shower and the manual on the bilge...Try dumping a gallon of water into the shower and see where it ends up...
Do the PO of your boat leave the counrty or something?
sailingfool is online now
post #12 of 14 Old 04-17-2009 Thread Starter
1979 C&C 30 Mk I - 2QM15
backcreeksailor's Avatar
Originally Posted by sailingfool View Post
Did the PO of your boat leave the country or something?
Let's just say the PO apparently sailed the boat, but never bothered to learn anything about the boat's systems. I did ask, but the PO said they never tried using the manual bilge pump even once in 6 years of ownership...
Anyway, I talked it over with the marina owner and he also felt that it's most likely attached to a bilge strainer that's screwed down somewhere under the shower pan. (It wouldn't make any sense for the manual pump to be connected directly to the shower drain). And the only available access to that area would be by removing the toilet and trying to get at it through the fiberglass base. But he believed as I do, that it was a bad position for the manual bilge pickup.
Not feeling the urge to disassemble a perfectly working toilet right now, I just stretched the pickup hose out as far as I could, cut it off, and the remainder retracted back into the pipe that feeds under the mast. I figure if any water comes out of it, it'll drain back into the bilge anyway.
So my electric is now in the lowest part of the bilge just behind the mast, my manual bilge strainer is now about 2' aft of the electric, and they're both working nicely.
I figure the manual pump will be more for emergencies anyway. So being at a point just slightly higher (1/2") than the electric seems like a perfectly acceptable location to me.
backcreeksailor is offline
post #13 of 14 Old 04-17-2009
chef2sail's Avatar
Ha Dog...good comeback. Actually the strainer has holes the size of #9 spaghetti vrs #16 angle hair strainer or square holes like a fettucini strainer. The admiral prefers visual cues to describe things vs its correct name like a strum box. God only knows what she would check if I told her the strum box holes were clogged
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #14 of 14 Old 04-18-2009
I think you need to take a look at the area below the shower sump with a good flashlight and maybe an inspection mirror...
sailingdog is offline
Devising a Better Bilge Pump Don Casey Seamanship Articles 0 06-02-2002 09:00 PM
Devising a Better Bilge Pump Don Casey Gear and Maintenance Articles 0 06-02-2002 09:00 PM
Devising a Better Bilge Pump Don Casey Cruising Articles 0 06-02-2002 09:00 PM
