Blogs
User Name
Old 10-31-2002
bantrybayboston bantrybayboston is offline
bantrybayboston is on a distinguished road
Running motor on dry land/stuffing box
Hey,
I was wondering if it is bad for the stuffing box to run the motor while the boat is out of the water. Once I start the enging I can fiddle with the gears to get it into neutral, but there is some time when the drive shaft will be spinning.
Thanks,
Kevin
Old 10-31-2002
Sailmc Sailmc is offline
Sailmc is on a distinguished road
Yes. It is definately a bad idea to run the engine out of the water. Your engine needs sea water for coolant and your stuffing box needs it for lubrication. You might be able to rig a hose for the engine but I don''t know what you could do to keep from burning up your packing or shaft seal whicever you have.
Old 10-31-2002
tsenator tsenator is offline
tsenator is on a distinguished road
a couple of seconds won''t kill you. Just don''t leave it in gear long.
Old 11-01-2002
nauticalrich nauticalrich is offline
nauticalrich is on a distinguished road
What if they have a dripless stuffing box?
Old 11-01-2002
They still require water for lubrication
Display Modes
vB code is On
LED''s vs. Incandenscent Bulbs for Running Lights?? Cap'nJeff Gear & Maintenance 7 07-30-2006 04:44 PM
Cal 33'' running rig dshearn Gear & Maintenance 10 05-12-2004 10:09 AM
Running rigging in colors? Jonathan316 Gear & Maintenance 8 05-01-2004 09:13 PM
LED running lights JohnDrake Gear & Maintenance 1 08-23-2003 11:55 AM
converting to running backstay homer79 Gear & Maintenance 2 01-20-2002 08:14 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
