04-17-2009
C&C Racer/ Cruiser
Echo Charger
I have bought a Xantrex echo charger to charge my starting battery from the main bank. I like the idea that has been presented in porevious posts. The charger has instructions for 12v/24volt
Two questions
1. I have a house bank of 6 105 6v trojans. Can I connect the charger leads to the positive of one of the 6 volts and the negative of the other 6 volt on the ones i have in series, which then go to the starter battery of same .
2. I know you are not supposed to mix batteries in a charging network bit can the leads go to a 12 volt starting battery or do they have to go to 2- 6 volt ones.
Dave
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
