-   -   spinnaker setup (http://www.sailnet.com/forums/gear-maintenance/5360-spinnaker-setup.html)
maestro 10-31-2002 08:53 AM
spinnaker setup
I want to use the spinnaker (which came w/ my boat but I haven''t used yet) next season on my boat. I have the chute, spinnaker pole, mast ring for pole and spinnaker halyard. What else am I missing???
I believe that I have to install a block at the masthead to run the halyard through?? And a block at the base of the mast to run the halyard back to the cockpit ( where all my other halyards run to) How about uphaul/downhaul for the pole??
Any help would be appreciated.
Mike C.
"Maestro"
Stede 10-31-2002 10:28 AM
spinnaker setup
If you have a West Marine catalog,(sorry SN!), dig it out. It has some good diagrams of spinnaker set up, sheet lengths,etc. If you don''t have a catalog, they probably have the same diagrams on their webpage under the "West Advisor section."
Jeff_H 10-31-2002 07:23 PM
spinnaker setup
Depending on the size of the boat you need a pole lift, foreguy (or spinacker pole downhaul), spinacker sheets, turning blocks at the stern of the boat and snatch blocks to use to twing the guy.
petercra 11-02-2002 10:45 AM
spinnaker setup
My boat came with a symmetrical spinnaker, and I purchased a sock (V.F. Shaw Chutescoop) for it, as well as an ATN Tacker. The Tacker is a plastic collar that fits around the headstay, and it allows the spinnaker (symmetric or asymmetric) to be flown without a pole (the tack is attached to the Tacker rather than the pole, its just as though the pole were forward against the headstay). It allows the tack of a symmetric spinnaker to be flown at pole height (as designed) without the sail rotating to leeward as it would if a tack line were led to the anchor roller.
Practical Sailor reviewed the ATN Tacker in its August 1, 1996 issue. The article says you can fly the spinnaker from 80-160 degrees true. I''ve found that to be approximately correct, perhaps a bit optimistic on each end of the range. Inasmuch as cruisers typically only use spinnakers in relatively light air, where tacking downwind is faster, the inability to sail dead downwind isn''t much of a problem.
The lines needed with this setup are halyard, tack line, and sheet.
With a regular pole you need a guy, spinnaker pole topping lift, and spinnaker pole foreguy, but no tack line. If you want to be able to gybe on a larger boat you''ll need two more lines: a lazy guy and a lazy sheet. It''s a lot of work to get it all hooked up and manage it.
If a sock is used there is another line (typically one continuous line for up and down). I recommend leading the line aft and having some sort of quick cleating arrangement. One doesn''t want to be on the foredeck of an out of control boat trying to douse the spinnaker. You need to be able to pull it down without worrying about a gust catching it and causing the sock to ride up again. Take a look at the spirt J boats. They have a couple of cam cleats on the side of the cabin house for the sock controls.
Jeff_H 11-02-2002 01:50 PM
spinnaker setup
I have not been impressed with the need for a spinacker sock. While they work, they don''t work well enough to justify thier use on boats under 40 or so feet in length. On Boats below that length it is really easier to flag the chute and drag it down the back of the mainsail. On the J-boats that I have been on they have stopped using the socks years ago. The problem with the socks is that it hard to reliably send the sail up without an hourglass. Then you are really in trouble.
I am not all that impressed with raising the spinacker on a Tackline and restraint. One of the easiest and safest ways to gain control and douse a chute in a building breeze is to flag it behind the mainsail. You really don''t have the option of doing that with most tackline set ups. Beyond that when sailing deep angles it is very easy to get a serious wrap with a tackline (think of going close to down wind with the spinacker pole almost on the headstay).
So while it may be true that a regular spinacker set up requires more gear,IMHO, it also offers a lot more options and is actually easier to use safely.
sandboy 01-21-2009 12:48 PM
A little trick when your making up your spinacker sheet's and Guy's & halyard make sure you buy snapshackles with a swivel if you buy them without when you launch the kite any twist in the rope under pressure twists the sail plus with the swivel's if you get an hour glass it spin's out by itself as soon as pressure is put on your sheet this solves 90% of hour glasses in fact went through the last three racing season's with every twist undoing itself
zz4gta 01-21-2009 01:09 PM
I have to agree with Jeff on the socks. I've used 2 different styles and I wasn't impressed with either. When the chutes loaded up they don't like to work (when you need it to work).
Sandboy gave some great advice I thought was common knowledge until I started racing on other's boats. Swivel shackles are a must. Standard equipment for chutes, just buy em.
The necessities are a halyard, a block or existing sheave at the top, 2 sheets, a pole up and pole down, turning blocks at the aft corners. Twings aren't a must have, save them until after you practice trimming w/o them.
sandboy 01-28-2009 07:31 AM
I found every now and then in my early day's without Twings that the spinnicker in a bad drop was more likly to end up under the boat or simply getting a sheet or guy caught arround the rudder or keel I disagree with zz4gta they cost very little and are worth the trouble from the start of setting up your spinnacker system cheers kerry
gaha_1 02-01-2009 10:31 AM
It don't hurt to ask
:cool: Well I guess alot of you guy's have used socks and don't like them. Well I wouldn't mind having one.Any donations would be great.Give me a e-mail if you can help .Thank you for your time
sassafrass 02-01-2009 01:47 PM
twings are good, and they help control in building weather. take down behind mainsail for short handing. no trouble. there are lots of diagrams online concerning how to set things up.
tom
