Yanmar starting question - Page 3 - SailNet Community
post #21 of 30 Old 04-19-2009
L124C's Avatar
Another guy in my marina had this problem on a 2GM. His motor used to fire up immeadiatly, now it cranks for awhile. I asked if he put the throttle at 2/3 as my 2GM manual recomends. He never needed to move the throttle, the motor just fired up. He now puts the throtle at 2/3 and the motor fires faster.
L124C is offline
post #22 of 30 Old 04-19-2009
Air Leak
Originally Posted by SteveInMD View Post
Well obviously people disagree on this one. I still believe you have a small air leak. Hence the extra cranking after the engine sits. Here's how to test the theory. After letting the engine sit, bleed the system before trying to start it. If it fires right up after bleeding it, you have an air leak. If there is no change and it still requires the extra cranking time, you don't.
I agree 100% with SteveInMD. I have recurring problems with a small air leak at the banjo joint on the low pressure side of the fuel supply system. The bolt holding the banjo joint in place tends to slacken slightly over time. As soon as this happens, a small air leak occurs and the engine then has to be turned over a lot more times before it will start quickly.
About twice a season I notice that the engine is not starting as normal. I then immediately tighten this bolt and the starting is normal again! Have though about using a thread locker solution but am reluctant to get this stuff anywhere near my fuel system!
I always keep the throttle wide open until the engine fires.
neilmcd is offline
post #23 of 30 Old 04-19-2009
As SD mentioned above - keep some copper crush washers on hand. They should only be used (crushed) a few times when tightening banjo bolts and vent screws. After that they will be the source of small leaks.
SteveInMD is offline
post #24 of 30 Old 04-19-2009
BarryL's Avatar
Bad Lift Pump
The only way to lose the prime is if you have an air leak.
Couldn't a bad lift pump cause a lose of prime?
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is online now
post #25 of 30 Old 04-19-2009 Thread Starter
nk235's Avatar
SD - i like your point about the copper crush washers for the banjo bolts - to be honest I think I have over tightened that before - especially mid summer last year when I noticed a little fuel leaking out of there. I never knew you weren't suppossed to really tighten that.
Also I have checked the fuel lines and near the primary and secondary filters and have noticed no leaks. Also my primeing pump seems to work very well. I notice good clean bursts of fuel when I bleed the filter direclty on the engine so I don't think that is the problem.
My plan of action is later this week head down to the boat - bleed the system at the Racor (if I do in fact have a priming pump on there) then the secondary fuel filter, then the high pressure pump. I will then give it a go. From others I have been speaking with they seem to say that they often get the same problem early in the season with the cold weather. Hopefully it is just that but i'm still going to bleed it anyway.
Also thanks everyone for your advice and opinions. I'm only 25 and each year I learn more and more about the different systems, maintenance and repairs. I like doing everything myself so I get to know how to do it so if I ever do an extended cruise I'll be prepared. Hopefully in the future when I am a seasoned vet I'll be able to return all the favors by helping out all the other newbies with questions.
Morgan 323
nk235 is offline
post #26 of 30 Old 04-19-2009
[/QUOTE]I like doing everything myself so I get to know how to do it so if I ever do an extended cruise I'll be prepared. Hopefully in the future when I am a seasoned vet I'll be able to return all the favors by helping out all the other newbies with questions.]
Good luck. With some care, a good manual and common sense, you will save yoursef lots of dough and gain invaluable experience. You may not have a pro mechanic close by the next time you have trouble, so learn what you can while there is no risk to life or vessel.
SJ34 is offline
post #27 of 30 Old 04-19-2009
Glad to help...I've noticed that people generally overlook the banjo bolt crush washers. Be aware that even if the banjo bolts don't leak fuel, they can leak air...
sailingdog is offline
post #28 of 30 Old 04-19-2009 Thread Starter
nk235's Avatar
True - I just ordered what I think are the crush washers from Torrenson marine but can I get these at any hardware store so long as I bring the one from boat with me or are these special for boats?
Morgan 323
nk235 is offline
post #29 of 30 Old 04-19-2009
You can probably get them at any autoparts store...but I don't think the hardware store will have them.
post #30 of 30 Old 04-19-2009
Barry
Yes, if it has a hole in the diaphragm. However, this too is an air leak.
Need help YANMAR engine mount Giulietta Gear & Maintenance 20 04-15-2010 01:15 PM
Yanmar 4JH2E air filter element garyroot Gear & Maintenance 8 03-30-2010 08:23 PM
Starting Battery - Yanmar 3GM JohnRPollard Gear & Maintenance 14 03-11-2008 12:31 PM
Yanmar - fuel injection pump question rperret Gear & Maintenance 7 05-24-2007 10:00 AM
Yanmar 4JH air filter k1vsk Gear & Maintenance 19 12-25-2006 01:17 PM
