Old 04-19-2009
StrightR is on a distinguished road
In water bottom cleaning
I am using VC Offshore for the first time and I believe it will be faster if cleaned frequently. Has anyone found a device (extendable scrub brush)that works well for cleaning from the dock?
Has anyone tried the Dri Diver?
RNS
Old 04-19-2009
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
My guess is that your VC Offshore bottom won't stand up to the Dri Diver for very long.
"Clean bottoms are FastBottoms"
Old 04-20-2009
I gues you would suggest scrubbibg using a diver. What yould you clean/polish it with?
Old 04-20-2009
tommays's Avatar
I use a REALLY soft brush i found at the walmart auto section for cleaning RVs and DIY it
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 04-20-2009
Allanbc's Avatar
Allanbc is on a distinguished road
Using this method, it helps if you attach a 2 or 3 liter plastic bottle to the back of the head of the brush. This causes the brush to want to float and the helps push it against the hull.
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
Old 04-20-2009
tommays's Avatar
The problem is removing to much paint which is why i do it in the water and even then i rubbed through some spots
It gets you real wide awake in the spring and fall and the sea monkeys in your shorts are also a real thrill
Tommays
Northport NY
Old 04-20-2009
Fstbttms's Avatar
Depending on the amount of fouling, try using a piece of carpet or a diaper. And yes, I recommend doing it by hand, in the water. Using a Dri Diver or similar device, you can't control the amount of pressure you are using to clean the hull, not to mention how abrasive the scrub pads that come with the device are. Also, those devices will not clean the keel, running gear, thru-hulls etc.
Old 04-21-2009
39512's Avatar
39512 is on a distinguished road
I care for 3 boats with VC, all well travelled, serious racers. We supply the diver with extra fine 3M sanding sponges, about 600 grit, and 3M blue sanding pads. We recoat the bottoms between 3 to five years, depending on the condition. But be advised that these are expensive bottoms to maintain. Both boats haul out for detailing before major regattas, otherwise the diver cleans the bottom at least once a week, sometimes twice. The only place I can use a brush is on the waterline and use nothing more aggresive than the blue soft bristle head.
Old 04-21-2009
Fstbttms's Avatar
FYI and FWIW, in-water burnishing is probably illegal in your state. It is a definite no-no in mine.
Old 04-22-2009
mahana27 is on a distinguished road
Fwiw??
Cleaning bottom in water??? Stevyboy Gear & Maintenance 45 02-03-2009 02:42 AM
Fresh water bottom paint Monesprit Gear & Maintenance 2 05-20-2008 10:53 AM
Mooring systems GoodOldBoat Gear and Maintenance Articles 3 10-09-2007 09:05 PM
Cleaning Water Tanks JouvertSpirit Gear & Maintenance 5 03-14-2007 10:37 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 05:59 PM
