Tired of all my electric ? - Page 2 - SailNet Community
post #11 of 22 Old 04-20-2009 Thread Starter
I figured the cost of lighting my boat my way at $30.00 because I already have most of the lights in the cabin. Your numbers are at $90.00 not including tax and panel box. If I leave all the working lights then later I could re wire the way I want. Could I wire my motor light and nav lights to a 9 vlt. with a solar charge?
lapworth is offline
post #12 of 22 Old 04-20-2009
Not and have them be legal. The boat's running lights are designed to operate on a 12 VDC system... running them off of 9 VDC will leave them out of spec and likely endanger you as well as be illegal. Anyone who knows anything about electricity should realize this.
sailingdog is offline
post #13 of 22 Old 04-20-2009 Thread Starter
Sorry I don't know alot about electricity, I was just reasoning that if some one made a portable light it would meet code. This maybe out of date but one of my books read " Vessel less than 20 gross tons ( under 40') portable R & G lights ready to show in sufficient time to prevent collision.
lapworth is offline
post #14 of 22 Old 04-20-2009
lapworth here is a running thread about legal lights. you might want to read it.
as for the flash light looking running lights for dingy's yes they might work, but only when under power.
there is a lot of misstatements here on lights, alot of people argue the USCG certified lights are the only ones legal. that is not true, it just means that the USCG has looked at and tested them and found them to be bright enough ( and proper viewable angles ) . there are other lights that are bright enough but the CG has not tested em. if i where to strap a 250 watt halogen to my mast as a steaming light, and it had the right viewable angles it would be legal even thou the CG has not tested it.
the catch comes in when you use a light that is not certified and something happens. the other person may try to blame it on your lights, you are then behind the 8 ball and need to prove the lights you used where bright enough
as for the electric end trying to run a 12 volt bulb on 9 volts would probably barely light the bulb.
if you dont want to spend as much you could build your own switch panel for around 20 bucks to control the running lights. as you only need 3 switches, running, steaming and anchor. if you dont have a motor you dont need the steaming, and if you dont have an anchor you dont need the anchor light. but i would not want to stop all the extra possible use i could get out of the boat by not having the extra lights. you are a short sail to annapolis, you might someday want to go up and anchor for the night for a romantic dinner. with the wife if you have one.
scottyt is offline
post #15 of 22 Old 04-20-2009
lapworth there is a running thread about legal lights. you might want to read it.
scottyt is offline
post #16 of 22 Old 04-20-2009 Thread Starter
O.k. it's raining so I'll get down there today and salvage what wires are good and buy a new battery. Thanks for all the ideas I was just trying to get around all these wires.
lapworth is offline
post #17 of 22 Old 04-20-2009
And this is one of them... since the USCG actually doesn't test lights ever.. they're not responsible for doing so. USCG certified lights means that the lights are tested by independent testing laboratories and found to meet the USCG set standards.... not that the USCG has tested and certified them.
the catch comes in when you use a light that is not certified and something happens. the other person may try to blame it on your lights, you are then behind the 8 ball and need to prove the lights you used where bright enough as for the electric end trying to run a 12 volt bulb on 9 volts would probably barely light the bulb.
Using non-certified lights is fine, until you're involved in a collision. At that point your liability can be increased by the use of non-certified lights. That also means that if you are not at fault, you can be FOUND partially or wholly at fault if you have uncertified lights.
Using 12VDC lights on 9VDC power is a good way to guarantee you'll get borked in court... not only are they not legal, they're also far more likely to cause an accident. The brightness of a light is one way people tend to estimate how far away they are... running 12 VDC lights on 9 VDC means they will be far dimmer than they should be, and may fool someone into thinking your boat is further away than it really is. If the boat you fool is a high-speed ferry or powerboat, the chance of that turning into a serious problem for you is pretty good.
As for using small battery powered lights, like those meant for dinghies, as long as you keep the batteries fresh, they should meet the whatever requirements they are designed for.
post #18 of 22 Old 04-20-2009 Thread Starter
Point well taken, I don't want to trick people hitting me. But the regulations are sometimes hard to interpit. I looked at the other light page and still see all the same codes no one ever mentions watts,amps or volts. They just mention hight,color,distance,ect.. I'll keep looking but don't worry if you see me on the bay I'll be up to code. Thanks for all the advice.
lapworth is offline
post #19 of 22 Old 04-20-2009
glad to help... as for the wiring... I'd recommend you read Maine Sail's page on wiring a boat...
post #20 of 22 Old 04-20-2009
nickmerc's Avatar
lapworth,
I jsut rewired my boat this winter. Your boat wiring project will be an easy one. Remember, around Annapolis the bay is very busy at dusk and night. There are alot of big and fast boats out there. This is not an area you want to cut corners on. If you need any advice, or want to discuss the project, PM me.
________
ZOLOFT SIDE EFFECT
nickmerc is offline
hybrid electric bluetommy77 Gear & Maintenance 11 10-20-2007 01:35 PM
Electric Motors and Sailing Vessels Mark Matthews Gear and Maintenance Articles 0 11-17-2002 07:00 PM
The Great Windlass Debate SailNet Seamanship Articles 0 11-30-2001 07:00 PM
The Great Windlass Debate SailNet Gear and Maintenance Articles 0 11-30-2001 07:00 PM
