Old 04-20-2009
SF—
MarineTex is an epoxy putty... from their website:
Marine-Tex is a heavy-duty structural epoxy, used to repair aluminum, fiberglass and wooden boats, reinstall loose or stripped fasteners, permanently bond dissimilar metals without galvanic corrosion, and fill gouges in wood, metal and fiberglass, making repaired areas stronger than before.
Marine-Tex is an excellent choice for repairing problem areas located below the waterline. Marine-Tex is resistant to water and many chemicals.
Originally Posted by sailingfool View Post
I would not use MarineTex as I would would worry that differences in expansion rates and shrinkage would result in cracks developing. Expoxy filler would be better, glass would be best.
the real issue with this repair is whether you will mind a bright white spot on the bow of your boat...what you would really pay the yard $450 for is their expertise in matching the gelcoat so the repair is hard to see, say from 10 feet away. Do it your self and you are likely to have a bright white spot on your bow for the rest of your ownership. If you are Ok with that, go for it, this would seem to be a cosmetic repair.
  #12
Old 04-20-2009
FishFinder's Avatar
FishFinder is on a distinguished road
I'm OK with that, I know my gelcoat job probably won't match. I'll save the money for when I hit something bigger ...
1980 S2 9.2A (30') in Anacortes, WA
Aux power 13hp Volvo MD7A
You may post attachments
You may edit your posts
The legacy of Philip Rhodes GoodOldBoat Good Old Boat 25 12-14-2012 07:34 PM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
Fill that hole GoodOldBoat Good Old Boat 0 07-23-2007 09:54 AM
First Fiberglass Repair SailNet Gear and Maintenance Articles 0 09-01-2001 08:00 PM
SEO by vBSEO 3.6.1
