Old 04-20-2009
nightowle's Avatar
nightowle is on a distinguished road
can I use bronze ball valves w/plastic thru hulls?
Searched old posts but found nothing as to whether I can use bronze ball valves on plastic through hulls. The through hulls are in good condition and I have bronze fittings from elsewhere, but not sure if these are compatible.
I would plan on using Teflon tape and thread compound to seat the bronze to the plastic.
________
S/V Don't Panic!
O'Day 27
Seattle, WA
“Navigare necesse est, vivere non est necesse” To Sail is vital, to live is not.
Old 04-20-2009
tager's Avatar
tager is on a distinguished road
Oh come on! Plastic does not suffer from galvanic corrosion. As long as the threads go, you have nothing to worry about!
Old 04-20-2009
nightowle's Avatar
I thought I may have remembered reading about the different expansion and contraction temps that these varying materials operate at.
________
S/V Don't Panic!
O'Day 27
Seattle, WA
Old 04-20-2009
tager's Avatar
I wouldn't worry about it... the plastic through hull is above the waterline, right? I would trust marelon below the waterline, but it should have a seacock then, not a valve.
Old 04-20-2009
nightowle's Avatar
no. a couple are below the water line and a couple are above, and given the limited access I wanted to go with valve vs. seacock right now. I know seacock is preferred.
________
S/V Don't Panic!
O'Day 27
Seattle, WA
Old 04-20-2009
JimsCAL's Avatar
JimsCAL is on a distinguished road
I believe the ball valve with have tapered pipe threads while the thru-hull will have straight threads. Not compatible.
Old 04-20-2009
First of all, you shouldn't be using PLASTIC through-hulls below the water line. The only "plastic" through hulls that are safe to use below the water line are the Marelon ones, which are glass reinforced nylon.
You can use Marelon through-hulls with bronze seacocks... but most sea cocks are NPT threaded while the through-hulls are NPS threaded. If you're going to do this, use a bronze flanged adapter instead... this will have female NPS threads on the bottom for the through-hull and male NPT threads on the top for the seacock.
Personally, I think that you'd be better off using Marelon valves with Marelon through-hulls....but if you don't maintain the Marelon valves properly, you will break the handles off of them when they seize up. The Marelon valves need to be exercised regularly—at least once a month—and greased once a year.
Hurricane Preparation Cruisingdad General Discussion (sailing related) 119 08-28-2011 11:24 PM
Marelon vs. Bronze thinredmohican Gear & Maintenance 22 05-23-2011 06:38 PM
Leaking marelan seacock on brass thruhull sailbot Gear & Maintenance 34 12-11-2008 09:34 PM
Mooring ball heads up!! Maine Sail Gear & Maintenance 15 06-13-2008 08:52 PM
How can you tell if bronze through hulls are sound? kmclarke Gear & Maintenance 4 05-26-2008 10:31 PM
