Old 04-20-2009
preservedkillick is on a distinguished road
Need an exhaust through hull
My current exhaust through hull is (was) a bronze threaded fitting where the threaded part has an OD of 1 5/8 inch. The rubber exhaust hose that was clamped to it seemed to fit ok, and appears to be water tight so I'm assuming that hose has an ID of 1 5/8 too. I've removed the through hull since the prior owner jammed what looks like a few inches of PVC into the hole and I messed up the fitting getting it out. In replacing the through hull, it seems I should use a threaded fitting that can accept a hose:
http://marineengineparts.com/shopsit...UC00THH125.jpg
The trouble is that a through hull that has a hose end for 1 5/8 is a really big through hull, and the hole in the hull would be huge. It seems that there's a quite a step down in material from the threaded part, to the hose barbed part of the fitting.
Since the original through hull seemed ok, I'll likely just get another threaded unit and use a couple of clamps. Do engine exhaust hoses readily slip over the barbed end of a hose through-hull?
What's the best though hull for engine exhaust?
-preserved
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30:
Old 04-20-2009
The best through-hull for exhaust systems are these...
Tips For Compound, Polish & Wax Maine Sail Gear & Maintenance 172 1 Week Ago 05:50 PM
Ryobi vs. Makita vs. Poliglow?? CLucas Gear & Maintenance 61 3 Weeks Ago 06:02 AM
Any Gearhead's? Capnblu Sailboat Design and Construction 40 11-23-2008 06:58 PM
C & C 121 Customer Response to Manufacturers Post camaraderie Tartan 0 09-10-2007 06:43 PM
Spring Hull Cleaning Tom Wood Gear and Maintenance Articles 0 04-05-2004 08:00 PM
