Old 04-20-2009
donhaller's Avatar
donhaller is on a distinguished road
Primer for bottom coat on bare fiberglass?
I just finished sanding down my transom mounted rudder to bare glass and re-coated with West System epoxy.
Will bottom coat adhere to the bare fiberglass resin if it is sanded before application? or do I need a primer?
I am painting the top part of the rudder with Interlux Brightside One part polyurethane in white. Can I just paint the whole rudder white with the Brightside and then paint the bottom coat over that?
Chesapeake Beach, MD
C&C 25 MKI, Hull No. 039
Old 04-20-2009
Don—
You're going to have to clean the rudder with a dewaxer like Interlux Fiberglass Prep Wash 202 and possibly sand it lightly. Then I would coat it with Interprotect 2000E barrier coating—IP2KE works quite well as a primer for all sorts of paints. Then you can paint the upper half with Interlux Brightside and paint the bottom half with anti-fouling paint.
Old 04-20-2009
donhaller's Avatar
Thanks Dog! Great Information as always
Old 04-20-2009
glad to help.
The legacy of Philip Rhodes GoodOldBoat Buying a Boat Articles 24 03-09-2012 04:06 PM
Theory on cause of Fiberglass Hull Blisters travistowle Gear & Maintenance 121 10-31-2011 08:59 AM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
First Fiberglass Repair SailNet Gear and Maintenance Articles 0 09-01-2001 08:00 PM
