Silicone - Page 2 - SailNet Community
post #11 of 21 Old 04-21-2009
Glad I found Sailnet
Bene505's Avatar
I'll use whatever the advice here is. There just has to be something that works, even if it has to be replaced every x months.
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #12 of 21 Old 04-21-2009
tommays's Avatar
Boatlife makes Sillycone and polysulfide (Life-Calk) and a combo (LifeSeal)
It use to be fun when they were down the street as i use to repiar there tube filling machines and stock-up
My boats PO used most everything and the only downside i have seen so far is you REALLY cant get the Sillycone OFF to the point of lifting gel coat BUT it did NOT leak
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #13 of 21 Old 04-21-2009
ASA and PSIA Instructor
All sealants have their proper and/or preferred uses, and silicone has a number of such on boats...usually where flexibility, removeability and thickness are important criteria. FWIW what comes to my memory are the OEM instructions for Beckson opening ports and replacement lens for several hatches ( see DIY-BOAT.COM - Hatch Lens Replacement 4/20/01) which specified to use only silicone as sealants.
sailingfool is offline
post #14 of 21 Old 04-21-2009
tommays's Avatar
Bene
You are dealing with massive damage from small leaks that rot interior wood
Tommays
Northport NY
tommays is offline
post #15 of 21 Old 04-21-2009
midlife crisis member
AllThumbs's Avatar
Bene,
If you eventually plan to replace the deadlight just use silicone to seal it up as best you can. If the surfaces are clean I imagine it will stay there for a year. You are sealing between the plexy and the aluminim frame correct?
I sail.
AllThumbs is offline
post #16 of 21 Old 04-21-2009
If your issue is that the lens in a hatch is leaking, then you should just remove and rebed the lens...using only silicone, unless the OEM has a different specific recommendation. It's a simple job, the work is mostly removing the old sealant from the lens and the alu frame. Get those clean, and resetting the lens is a piece of cake, and it will last for many years. Smearing a coat on top may not be successful, and is not likely to look too good.
post #17 of 21 Old 04-22-2009
And if you take the time to do it right immediately, you won't spend all the time trying to fix it later, or fix the damage from the leaks the half-assed approach will leave you to deal with.
sailingdog is offline
post #18 of 21 Old 04-22-2009
MC1
What is the best way to remove the lens, using a flat razor blade from underneath or what?
MC1 is offline
post #19 of 21 Old 04-22-2009
Bene505's Avatar
Yes the lens is leaking. I ought to try taking it apart and rebedding it. Not sure there's a downside since I'll have to get it professionally done anyway, if I do nothing or if I screw it up.
Either way, I REALLY want to stop the leaks.
Bene505 is offline
post #20 of 21 Old 04-22-2009
jarcher's Avatar
Yeah, leaks REALLY REALLY SUCK! My boat has a seemingly endless supply, so I feel your pain
My guess is that you'll find fixing this one of the easier jobs on a boat.
jarcher is offline
Is Marine Silicone any different? tausap Gear & Maintenance 38 1 Day Ago 01:01 PM
Tips For Compound, Polish & Wax Maine Sail Gear & Maintenance 297 4 Days Ago 09:07 PM
GE Silicone I vs. Silicone II? SEMIJim Gear & Maintenance 13 08-09-2007 10:41 PM
Old silicone removal? AlexSchmoll Gear & Maintenance 5 12-09-2006 07:26 PM
Silicone bottom paint? VIEXILE Gear & Maintenance 2 05-16-2002 10:30 AM
