Old 04-21-2009
backcreeksailor's Avatar
1979 C&C 30 Mk I - 2QM15
backcreeksailor is on a distinguished road
Silicone
After reading through lots of posts here, I've gotten the message that in almost every case:
Boat + Silicone = BAD
So if silicone contaminates fiberglass so that nothing else will adhere to it; doesn't do anything useful for leaky windows; and should never be used to re-bed hardware...
Does "marine grade" silicone have ANY useful purpose? And if not, why do they continue to sell it in every boat supply store on earth?
Old 04-21-2009
Don Radcliffe
donradclife is on a distinguished road
Silicone causes marine painters fits, but if you are not planning on awlgriping anytime soon, it is probably the best compound for bedding windows and hardware which you want to be able to remove. It works better when thicker, allowing for some expansion and movement, so countersink the holes when you are mounting hardware, and don't squeeze it all out when you are bedding windows.
The best silicones I have used are the 'neutral cure' ones, but the US doesn't seem to have heard of them.
Old 04-21-2009
AllThumbs's Avatar
midlife crisis member
AllThumbs is on a distinguished road
What they sell at a store has nothing to do with whether it is a good product for a specific purpose, and everything to do with whether people will buy it. If people want silicone, a store will have it available, lest the go elsewhere to buy it.
Eric
Old 04-21-2009
johnshasteen's Avatar
johnshasteen is on a distinguished road
Boat + Silicone = BAD?
Silicone might be okay in the northern climes, but down on the Gulf Coast where boats are in the water year, even the best marine silicone is worthless. In the brutal summer sun and humidity it turns black, and looses it's adhesive qualities - you can pull it off by hand. Use either 3M or BoatLife caulking.
s/v Paloma, Bristol 29.9, #141
Slipped in Bahia Marina, easy access to Corpus Christi Bay and the Gulf of Mexico.
Old 04-21-2009
jarcher's Avatar
jarcher is on a distinguished road
What about those so called "hybred" products that are part silicon, part something else?
Old 04-21-2009
AllThumbs's Avatar
I think "boatlife" is a hybred. It's supposed to be pretty good for bedding plastic hardware, such as acrylic or polycarbonate portlights.
Old 04-21-2009
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
Can I use it for my leaky hatches? I really don't want to spend $500 getting them re-done this year. I'd rather smear something around the metal to polycarbonite (?) junction (inside and out maybe) and forget it -- even if it means doing it agian next year. Boat is in southern New England. Lewmar hatches.
Old 04-21-2009
I wouldn't use silicone for this... given that most "quick repairs with silicone" look like crap and work about as well.
Old 04-21-2009
AllThumbs's Avatar
SD, I think he is asking about using BoatLife for this, not silicone...
Old 04-21-2009
jarcher's Avatar
Yes, but if a hybred has silicon in it, why is it safer to use than silicon?
Tips For Compound, Polish & Wax Maine Sail Gear & Maintenance 172 1 Week Ago 05:50 PM
Is Marine Silicone any different? tausap Gear & Maintenance 30 04-09-2009 11:54 AM
GE Silicone I vs. Silicone II? SEMIJim Gear & Maintenance 13 08-09-2007 10:41 PM
Old silicone removal? AlexSchmoll Gear & Maintenance 5 12-09-2006 07:26 PM
Silicone bottom paint? VIEXILE Gear & Maintenance 2 05-16-2002 10:30 AM
