-   -   LED Interior Dome lights (http://www.sailnet.com/forums/gear-maintenance/53751-led-interior-dome-lights.html)
recycle 04-22-2009 04:33 PM
My brass dome lights are not brass and very tarnished. I'm thinking of replacing them with LED brass dome lights. I came across SeaSense brass or stainless LED dome lights interior for under 40 bucks per light. Has anyone tried these lights and are they any good?
LUNA
Tartan 3800
RI
sailingdog 04-22-2009 05:13 PM
you probably won't like the color/quality of the light coming from them.
higgins 04-22-2009 05:25 PM
SD, could you explain that a bit in detail ?
I was about to buy them myself. What's the problem,
light temperature ? intensity ?
Mimsy 04-22-2009 06:36 PM
Most LED lights throw a really blue light. It can be hard on the eyes. I saw a boat that had Alpen Glow lights installed and they were really nice. Not too blue at all.
Maine Sail 04-22-2009 07:48 PM
The best
The absolute best bang for the buck is to use some ABI surface mount lights and then add a Sensibulb.
This fixture is $21.99 ABI 7" Light Stainless Steel they also make it in Titan Tuff brass which is $33.00
http://www.defender.com/large/700041_l.jpg
Sensibulb $37.99
For under $60.00 per fixture you'll have a killer set up with the same warmth as an incandescent bulb!!
Cheap LED bulbs perform like cheap LED bulbs. The Seasense bulbs are antiquated LED technology and a complete waste of your hard earned money. If you want snake oil there is plenty of it in LED bulbs. Buy from a reputable company using good state of the art technology like Cruising Solutions or SCAD/Sensibulb.
sailingdog 04-22-2009 08:35 PM
Light temperature, durability, intensity, coverage, etc... all of the above.
Would second going the Sensibulb route....since they are by far the best solution for interior lighting currently.
recycle 04-23-2009 08:53 AM
Sounds good. I saw the attractive price and got to thinking. I'll check out the ABI and sensibulb.
LUNA
Tartan 3800
christyleigh 04-23-2009 10:04 AM
If you are putting the Sensibulbs in a dome as pictured you should be fine. While they may be technically the best..... for me they proved to be very fragile and extremely ugly (a circuit board) because there is no way for me to cover the light/circuit board with a lens. I bought a few last year after MS's recommendation and I certainly agree the light is bright and the color is quite acceptable. The problem I have is that all the ceiling lights (about 10) on my boat are little 2" diameter recessed adjustable fixtures. The wires to the circuit board are floating free and one of them popped off during installation. Again I say MY Problems are only because of MY Specific Light Fixtures, but as for the fragility of the lights themselves I would be very cautious during installation.
nickmerc 04-23-2009 03:22 PM
The other benefit of a standard fixture with LED bulb is as the LED technology changes, you will not have to buy all new fixtures to upgrade, only new bulbs.
________
Live Sex
KindOfBlue 04-28-2009 10:10 AM
Do the Sensibulbs fit in the 5 1/2" ABI fixture? I don't have room for the 7" and I think that 2 Sensibulbs in the 7" is a tight fit.
Also you say $60 per fixture, but my math is close to $100 (2 bulbs + 1 fixutre) or are you only using 1 Sensibulb along with 1 Xenon that's included?
Sensibulb $37.99
