Running roller furler line outside stancheons.. - Page 2 - SailNet Community
post #11 of 20 Old 04-23-2009
The one pictured is a pretty good design...and fairly new... the Schaefer ones are ankle biters... and not using them will make you much happier and leave you needing fewer bandages...
Originally Posted by groundhog View Post
Thanks for the great info and the link to the previous post.
I will definitely be using one of these.
SD, do you know if harken has improved their design?
gh
sailingdog is offline
post #12 of 20 Old 04-23-2009
chef2sail's Avatar
Ours like Patricks are on the port toerail. The are out of the way and pull in furling line on puts no pressure on the stantions that way.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #13 of 20 Old 04-23-2009
Moderator
JohnRPollard's Avatar
gh
I found the design was just about perfect.
In my other thread SD cautioned about over tightening, and I mentioned that it had not been an issue. But I can see how it could be if you torqued them.
Don't use the long arm of the allen key. Just snug them with the short arm.
JohnRPollard is offline
post #14 of 20 Old 04-23-2009
Of course, the block that had the separation problem was a stanchion mount turning block, which has a lot more force on it than does this design, since this design lets the line help hold the block in place.
post #15 of 20 Old 04-25-2009 Thread Starter
SD, why do you say the schaefer ones are ankle biters?
Are you talking about the ones that encircle the stancheon?
I also heard that the gerhauer design used to be like the scheafer design with one sheeve. Now it's like the harken with two. Can anyone confirm this?
thx,
gh
groundhog is offline
post #16 of 20 Old 04-25-2009
No, I'm talking about the ones that look like this:
IMHO, they're ankle biters since if you walk too close to the stanchion base, they'll clip you right at the ankles pretty hard.
thx,
gh
post #17 of 20 Old 04-25-2009
Moderator
GH,
Did you read the linked thread where I discussed the various options available and explained why I swapped out our old Schaeffer leads, i.e. because they were "ankle biters"? I think the photo immediately above (from my boat) clearly demonstrates the problem.
I was referring to the old style more so than the newer outboard "Clear Step" version by Schaeffer (i.e. the ones that "encircle the stanchion"). But I still think the Harken OSLBAs have an advantage in that they really do not protrude inboard of the stanchions, minimizing the possibility of clipping ankles.
post #18 of 20 Old 04-25-2009 Thread Starter
Ok, now I understand.
thx.
post #19 of 20 Old 04-27-2009
Irrationally Exuberant
thx,
gh
I've got the Garhauer stanchion blocks and they do have 2 sheaves. I like them because the stainless blends in with the stanchion. They do leave marks on the stanchion (stainless on stainless) but they've never bitten an ankle.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #20 of 20 Old 04-27-2009 Thread Starter
Ok, now I have another problem with my plan and need some advice.
I was at the boat on sunday and looking at my stancheons to figure out how to run the line. Well, between the two midship stancheons is right where all my shrouds attach. Right to the toe rail area on the edge of the boat.
I still want to run the line outside, but now it seems like I have to put something to bump the line outwards further on these two stancheons to miss going straight through the shrouds.
Thx,
gh
Roller Furling Lay Up Tom Wood Gear and Maintenance Articles 0 10-21-2003 09:00 PM
Installing Roller Furling Sue & Larry Gear and Maintenance Articles 0 08-09-2002 09:00 PM
Kerosene Running Lamps Sue & Larry Gear and Maintenance Articles 0 07-04-2002 09:00 PM
Running Backstays Dan Dickison Gear and Maintenance Articles 0 05-14-2002 09:00 PM
Off-Season Seminars, Part Two Dobbs Davis Racing Articles 0 01-09-2002 08:00 PM
