Old 04-24-2009
Maine Sail's Avatar
Replacing A Cutlass Bearing (Photo Heavy)
Replacing a cutlass bearing is not a tough project but does require some thought. On some boats the bearing is inside the dead wood making replacement more of a task than when it's mounted in a strut. These instructions deal with replacing a strut mounted cutlass bearing.
While there are some commercial tools designed for cutlass bearing removal they are not always 100% reliable and can even cause more damage than they are worth. My particular boat yard no longer uses presses for cutlass removal as they have seen far too many problems. Even when new the bearing has a very tight press fit into the strut and it should. The set screws are not the means of holding the bearing into the strut. The press fit is what holds the bearing in place and the set screws are simply a means of back up.
Often times when a bearing has been installed for a while they can become frozen or corroded in place. Using a press, either hydraulic or mechanical, for removal, can potentially distort the bearing and score the mating surfaces.
While many folks have had luck with presses they are not 100% reliable. If you ruin your strut in the process you are into a MUCH bigger expense and a very in-depth and time consuming task of replacing and aligning the new strut.
The first step is to remove the set screws. Often times they are filled with crud and growth and must be cleaned before you can get an allen wrench in there. I find a nail or coat hanger a good tool for cleaning out the allen heads. You may also want to hit the set screws with some P.B. Blaster before attempting to remove them. If you see what looks like red or blue Loc-Tite you may want to heat the set screws with a heat gun before trying to remove them. This will avoid the potential stripping of the allen heads.
In this photo you can see I have already made the cut through the bearing. The location of this cut is critical if your strut uses set screws. Some boats do not use set screws so the cut location is not as critical but on struts with set screws it's far easier to utilize the set screw tappings to aid in breaking free the bearing.
The location of the cut should be opposite either the top or bottom of the set screw tappings so that the bolts are pushing right at the cut to split it inward. the picture denotes the optimum cut location of you have set screws.
Making the cut can be done two ways: #1 Cut it by hand with a hack saw #2 Cut it mechanically with a Sawzall.
I DO NOT recommend using a Sawzall if you are not experienced in its use and you have the skill finesse it for exacting use. If using a hack saw you simply remove the bade and insert it throught eh bearing then re-assemble the saw around the strut. Some folks say to install the blade upside down but I honestly find it more accurate and easier to be holding the handle in its proper hack saw orientation.
When making the cut DO NOT cut all the way through the bearing and DO cut evenly. Applying more pressure on one end of the bearing than the other will result in an uneven cut. The saw blade MUST have 100% even pressure to make an even cut. You want both ends of the bearing to become paper thin at the exact same time. If you do cut all the way through and score the inner surface of the strut it's not a huge deal, but, if you do this every time you change a cutlass it will get bad over time.
In this photo you can see that I have cut the bearing paper thin and not scored the strut in the process. I used a Sawzall with a very fine tooth metal cutting blade. I have lots of experience with recriprocating saws and feel quite comfortable with them. You'll have to make that decision on your own. If you are in the least bit questioning your skill please use a hack saw with a good quality blade like a Lennox.
With the bearing cut paper thin I use a cold chisel and dead blow hammer to make the first split of the bearing by setting it on the edge and pounding inward. Be careful not to damage the strut when doing this. This will start the ripping of the very thin surface left in the cutlass bearing. Once you've started the rip simply insert some hex head bolts into the set screw holes and tighten them evenly and you'll collapse the cutlass inward relieving the matting surface pressure in the process.
If you do not have set screws your next move is to use a maple dowel or piece of thin fiberglass pounded between the strut and the bearing to split it along its entire length. Please do not use a screw driver or metallic object to pound and split the bearing. A metallic object could quite easily score the inside of the strut as it may be a harder metal. Use an object that is softer in composition than the strut.
In this photo I've tightened the bolts and collapsed the cutlass bearing relieving its press fit pressure from the strut. You can achieve the same results with a maple dowel pounded between the bearing and strut after initially bending it with a cold chisel & hammer to get the dowel started.
Once you have collapsed the bearing inward simply grip it at the bend with a pair of Vise Grip pliers and twist with the direction of the bend, as shown, while pulling at the same time.
The next step is fairly simple but you must be careful not to remove too much of the struts surface when cleaning it. To clean the bearings mating surface I use a Dremel with the Magic Wand attachment and the burgundy Scotch Brite/abrasive wheel product# 512E. Using the Dremel this cleaning task takes all of about 30 seconds. The burgundy abrasive wheel is a 320 grit equivalent. If you do this by hand use a 320 wet sand paper, or close to it, so you do not damage or remove too much surface area.
If you remove to much of the strut when cleaning you can literally destroy the tolerances and press fit nature of the bearing in the strut. Remember this is simply a cleaning of the bearings mating surface not a sanding.
Installing the bearing is actually quite easy. It requires some threaded rod, use at least 1/2", about four nuts, and some large and thick washers. You may also need some Ivory hand soap.
The most difficult part is actually getting the bearing started. You want it to go in perfectly straight so care must be taken to get it perfectly straight before beginning to tighten the threaded rod. If it goes in crooked it will bind and yo can ruin the bearing.
You may want to lube the inside of the strut and the outside of the cutlass with regular Ivory soap in bar form. Once the soap gets wet it dissipates and unlike grease or other lubes will not compromise the press fit of the bearing in the strut.
A couple of tips from this photo. I use a spark plug wrench to slide over the threaded rod and a deep drive socket on the other end. There is tremendous force required to press the bearing into the strut so I use two heavy duty washers with the smooth sides facing each other. Most all washers have a smooth side and a rough side..
Between these two washers I apply some wheel grease so they rotate on each other easily. This prevents the washer from wanting to turn on the face of the cutlass bearing and really makes it much easier to tighten and press the cutlass into the strut.
Please do yourself a favor and use THICK washers and multiples if you need to. Thin washers will bend or dish and can destroy the cutlass bearing by flaring the end. Also remember to use at least 1/2" threaded rod. This is not a job for wimpy threaded rod.
The finished product! Press it in until flush with the end of the strut, re-install the set screws with blue Loc-Tite, and you're done.
Unless you own a hydraulic or mechanical press, and know how to use it, the easiest and most reliable way to replace a cutlass is to do it with the shaft out. I would recommend replacing a cutlass any time you have the shaft out as they are cheap insurance.
This entire job start to finish, after the shaft was already removed, even with taking these photos, was about 30 minutes.
______
-Maine Sail / CS-36T
Old 04-24-2009
PalmettoSailor will become famous soon enough
Maine, I just replaced my bearing with the shaft in place using a "Strut Pro" tool. Unfortunately, I was under the gun to get the job done and the tool shipped to the next C36 member so I wasn't able to document the job at all. Googling "Strut Pro" will bring up the page detailing how the tool is used.
If you have access to such a tool tool it offers another option for those needing to replace a cutlass bearing in a strut with the prop shaft in place.
Edited to add: Isn't a "Cutlass Bearing" more precisely a "Cutlass bushing" I always thought it was a bushing if it didn't move and a bearing if it spun.
PalmettoSailor (formerly midlifesailor)
s/v Palmetto Moon
1991 Catalina 36
Old 04-24-2009
camaraderie's Avatar
moderate?
Maine...another great photo essay that will be useful to many. Thank you!
Old 04-24-2009
denby's Avatar
Location: Dead Sea, some times called Long Island Sound
denby is a jewel in the rough denby is a jewel in the rough denby is a jewel in the rough denby is a jewel in the rough
Great job, thanks for the info.
Dennis
O'Day 302
Be careful or i will do what the voices tell me to do
To get the most from Sailnet, follow the link in
's signature.
Hey stuffit "Get a life"
Old 04-27-2009
CarelessNavigator's Avatar
CarelessNavigator is on a distinguished road
The reason you would use soap, soap will not swell the rubber inside the bearing if you are sloppy . Oil and grease are both petroleum based and may cause the rubber to swell and cause premature failure. Vegetable oil is often used as well it does not harm the rubber.
Old 04-27-2009
There should be a sub forum of useful tutorials just like this one in Gear and maintenance.
Old 04-27-2009
Joesaila's Avatar
1977 Morgan OI 30
Joesaila is on a distinguished road
What if?
Again, this is good. My problem [I think] is that my shaft goes right through the skeg. I am going to look but I'm pretty sure I don't have the two screw tap holes your pictures show. So it may be a matter of driving out the old bearing w a dowel....I believe a post exists for dealing w that, but if you have a suggestion, I'm listening.
My formula for living is quite simple. I get up in the morning and I go to bed at night. In between, I occupy myself as best I can.
Cary Grant
Old 04-27-2009
erps's Avatar
the pointy end is the bow
Joesaila,
Rather than driving out the old bushing with a dowel, they make a bushing removal tool that presses them out using two threaded rods as already mentioned by midlifesailor. That way you're not transferring the hammer blows through the strut to the hull.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 12-19-2009
Strutpro is on a distinguished road
Cutless Bearing Replacement WITHOUT removing shaft
Thanks you for mentioning our product and the great photo!
With Strut-Pro you can do the same replacement but in a fraction of the time because you don’t remove the shaft or strut.
Check out the Strut Pro Cutless Bearing Replacement Tools on the Strutpro Website, strutpro dot com.
You can contact us with questions, pricing etc.
Thanks again,
The Strutpro Folks!
Repairing A Marine Alternator (How To / Photo Heavy) Maine Sail Gear & Maintenance 9 03-17-2009 12:12 AM
Max weight of shat/prop on cutlass bearing kaakre Gear & Maintenance 1 05-30-2008 06:31 PM
PS 37 Cutlass Bearing waypt1 Pacific Seacraft 5 01-15-2008 03:03 PM
Installing a Cutlass Bearing Mark Matthews Gear and Maintenance Articles 0 04-26-2002 08:00 PM
Cutlass Bearing Query SailNet Gear and Maintenance Articles 0 06-06-2001 08:00 PM
