Old 04-25-2009
geoffschultz is on a distinguished road
Spraying AwlCraft Using Brushing Converter?
I'm in the process of Awlgripping my boomvang. I've got the boomvang etched, undercoated and primed with #545 primer and was about to top coat it with Awlcraft. However, I just discovered that my Awl-cat #2 spraying converter is hardened up and all that I have is the #3 Brush Converter.
According to what I've read, Awl-Craft is a spray only material, and I get a much better coat by spraying, so I really want to spray. However, a pint of the converter is $50+, so I'm not keen on spending that and there's no place around here to get the spray converter.
So, does anyone know what the difference is between the spraying converter and the brushing converter? What happens if spray using the brushing converter?
-- Geoff
Old 04-25-2009
tommays's Avatar
If your talking about catalyst (converter ?) then i can see and issue as none of the reducers (thinners) cost that much money ?
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 04-26-2009
timebandit's Avatar
timebandit is on a distinguished road
Usually thinners for brushing allow the paint to flow out longer to allow the brush marks time disapear.
You might have to be carefull and watch for runs and sags and more time between coats if you spray.
Rick
Mac 25
Copernicus
Southern California
I am not a prejudice racist sexist bigot. I just hate stupid people.
Old 04-26-2009
billyruffn's Avatar
billyruffn will become famous soon enough
Get the right converter -- $50 is cheap when compared to what it will cost you to re-do the job. Awlcraft can be rolled when applying non-skid but it's not easy to do, and I wouldn't recommend trying to roll it where a shiney finish is desired. Spraying is much easier, but you've got to have the chemistry right -- I think that if they thought it was OK you to spray with brushing converter they'd say so.
DC/DC Converter freya39 Electrical Systems 5 04-23-2009 07:11 PM
