04-26-2009
Just curious, what did the gate valves supply water to???
Yes, removing the valves and putting a female blanking plug or pipe cap over the through-hull is a solution, but you may have a problem with thread type, since through-hulls are NPS thread and the pipe cap may be NPT thread. However, it will probably work in that case, but it won't be ideal.
