04-26-2009
BTW, it would help if you said how many AMP-HOURS the battery bank was, CCA stands for Cold-Cranking-Amps...and is a rating of how much power it can output for a very short period of time... and if your batteries are rated in CCA, they are likely starting batteries, not the deep-cycle batteries you really should have.
I'd also point out that the term battery can refer to a bank of batteries that are connected together to create one large logical battery, and that most batteries are actually six, smaller TWO volt batteries, connected in series.
One other problem with upgrading to an electric head, is wiring. You would need to run fairly heavy wire up to the head... since the macerator pump takes a bit of amperage.... and the run may be fairly long, since the heads on most boats are forward, and the battery banks are usually aft.
Originally Posted by davewild
I am thinking about replacing the old hand pump toilet on my sail boat(cause I'm sick of the kids not being able to do it). However my experience with electric units is limited to pushing the button in wonder on friends power boats. Can any one give me any info on makes/models to look for or avoid? Obvious issues are reliabilty and current draw. Boat is a 33' 1989 GRP cruiser/racer and batteries are 2x 720cca 12v on seperate banks(can 1 battery be a bank?). Any advice would be welcome.
