Old 04-26-2009
DrB DrB is offline
DrB is on a distinguished road
I love Yanmar Diesels
We're scheduled to splash on Friday (I hope) so I was down at the yard doing the final prep work. One of the things we do is fire the motor on the hard for 10 minutes to make sure it fires alright and was bled properly. Today would be the first time we fired our motor since November 10.
Connect the battery, turn the key, push the button, motor catches in less than two seconds on the first try. My neighbor was impressed. Ran it for 10 minutes, good water flow, a just a hint of normal very light gray smoke, and it sounded nice and smooth. Upped the RPMs to 2000 for a few minutes and everything looked great.
Can't wait till Friday.
I hope everyone can get in the water soon and has a great season.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
Old 04-26-2009
okawbow is on a distinguished road
My 33 year old YSE8 is running almost before you hear the motor crank as long as the temp is over 70. That engine has several thousand hours on it with only normal maintenance and new gaskets and injector last year. Compression, clean fuel, and air makes it run every time.
Chuck
Bristol 24 on Midwest lakes, rivers, to the Gulf
Old 04-26-2009
dacap06 is on a distinguished road
Send a message via Yahoo to dacap06
Yanmar 2GMF here
I guess my 84 Islander was repowered by some PO with the 2GMF. I think that year and model came with with a Volvo Penta.
Anyway, after sitting on the hard for two years (luckily with a full tank of Diesel), that Yanmar fired up immediately last Autumn during the Survey. I was impressed at the time and wondered if it was fluke. It wasn't. The engine has fired up within 2 seconds every time I have started it since, even when the temp was only 60F. Not bad for an engine with no glow plugs.
Oh, don't get me wrong. It has its moments. Twice I had to bleed the fuel lines this weekend. That doesn't count the bleed when we replaced the fuel filter. Each time, after about 20 minutes, it started running erratically. It must be sucking air into the fuel lines somewhere, but darned if I know where. Now that I got my first good sailing weekend in, I'll have to look harder for something that's a little loose.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
Old 07-18-2009
LakePirate's Avatar
LakePirate is on a distinguished road
I too have a 2GMF in my 84 Islander 30. I do believe it is the original engine though.
After sailing it for two years now with out any problems this past weekend while motoring into the marina it started loosing rpms and then died. I am assuming it ran out of fuel even though the guage is on 1/4 tank. I've never run it that low before. Actually in two years I have only put 5 gallons of fuel in it. When I did it did move the guage to around 3/4. So now my task for today is restarting it. I'm planing on first puting some fuel in the tank, checking the filter, try cranking it once, if it doesn't fire then start the bleeding process. Any Other suggestions would be helpful.
Old 07-18-2009
badsanta is on a distinguished road
While your at it replace the filters if you have not that in awhile. I would also fill the tank.
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
Old 07-18-2009
FishFinder's Avatar
FishFinder is on a distinguished road
Check your fuel filters for sure for signs of contaminated fuel and also check your fuel tank + pickup if you can. I had a similar situation happen last month, I was running the fuel tank lower than I ever had before and whammo dead engine. Turned out that contaminated fuel + fuel tank seriously clogged the fuel pickup inside the tank (which had a screen over it) and made a mess of every fuel filter on down the line. Something about running with a low tank level caused the goop ... which I should have discovered and cleaned BEFORE all this happened ... inside the tank to find it's way into the pickup.
I've since installed a fuel tank inspection port, completely cleaned the tank, replaced the pickup, and am in the process of cleaning most of the fuel components. No fun having an engine die at a bad time.
1980 S2 9.2A (30') in Anacortes, WA
Aux power 13hp Volvo MD7A
Old 07-19-2009
nereussailor's Avatar
Coastal Traveler
nereussailor is on a distinguished road
Send a message via Yahoo to nereussailor
I have a Yanmar 2gm in my H30. It hadn't been run for 18 months. I turned the key, pushed the button and it fired right up. They really are great motors.
Now if they could just put the dipstick where a human could reach it.
Dave
Old 07-19-2009
Dave
What? you dont have 8 foot arms and double elbows, give me a break.
Old 07-20-2009
Coastal Traveler
8 foot arms
Don't forget, Your eyes have to be on 3 foot antennae too
Dave
Old 07-20-2009
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
I have a 2GM20f on my boat. In 10 years, I never found the dip stick.
Never Forgotten
Need help YANMAR engine mount Giulietta Gear & Maintenance 20 04-15-2010 01:15 PM
Beneteau vs. Yanmar – Green vs. Red Cooling Fluid Swesail Gear & Maintenance 37 04-14-2009 12:32 PM
Yanmar Problem Solved... Warren M. Gear & Maintenance 1 09-01-2008 09:39 PM
Yanmar 3gmd Question nk235 Gear & Maintenance 4 03-12-2008 04:48 PM
Question about marine diesels bdkorth Learning to Sail 9 07-03-2002 10:52 AM
