04-27-2009
On most diesel engines, there's nothing electrical which would cause the engine to die (unless you have either an electric fuel pump or a short in the stop solenoid).
Diesel problems in order of occurence are: (1) fuel; (2) fuel; and (3) fuel. You've very likely got a dirty fuel tank, and maybe some bad or old fuel.
Have the tank cleaned. Make sure the pickups are clear. Change the filters. Check to be sure all fuel connections are tight. Yes, it's a dirty job and a lot of work, but if your tank is dirty partial measures like changing the filters won't do the trick.
Bill
