04-27-2009
You could probably add something to the AC panel to shut off the solar power when the shore power is live.
Originally Posted by wind_magic
Hmm, seems like it would be easy to automate this - if the charger were going through a diode (bad idea) all you would have to do is use a bit of charge current to switch a normally connected relay into open position and automatically disconnect your panels as a charge source. Not running the charger through a diode, however, I'm not sure how you'd implement it unless you actually had a controller that would periodically disconnect the panels, read the voltage, and then decide whether to reconnect the panels based on whether another charger is hooked up.
I guess a manual switch is the most simple solution.
