04-27-2009
yanmar question
hi all-
for all you yanmar people: I have a 2gm20F; had the boat about a year and have noticed that the fuel intake "nipple" on the engine (ie where the fuel line from the fuel filter connects to the engine just above the primer pump) is always a bit wet with diesel. I just changed all my fuel lines and was hoping that a new line/tightened-up hose clamp would get rid of that leak. As soon as I popped off the old hose the nipple swung down (ie the nipple piece was totally loose on the engine). I took it off, cleaned it, replaced it and put the new hose on tight. At rest there is no leak but I did note after running the engine for a few hours yesterday again there is wetness back there (I don't see it actively dripping but still wet). Any ideas? What else might be leaking?
thanks
brad
Little Dancer
'88 Caliber 28
