Mainsheet line and tackle. - Page 2 - SailNet Community
post #11 of 31 Old 05-01-2009
tommays's Avatar
On a 25' raceboat 6:1 is just to much line in the cockpit
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #12 of 31 Old 05-01-2009
Not just a member
It is rigged like this:
Not as much line in the cockpit, you pull both or one side only.
Dan
"Wind Wing"
Piewiet 850 / Dutch Flyer 28
Solomons, MD
Chesapeake Bay
"For the truth is that I already know as much about my fate as I need to know. The day will come when I will die. So the only matter of consequence before me is what I do with my allotted time. I can remain on shore, paralyzed with fear, or I can raise my sails and dip and soar with the breeze."
Richard Bode
-- from First You Have to Row a Little Boat
motovationcycles is offline
post #13 of 31 Old 05-01-2009
tommays's Avatar
We did it from old style 6:1 to new style 8:1 its a LOT more line
Tommays
Northport NY
tommays is offline
post #14 of 31 Old 05-01-2009
blt2ski's Avatar
6-1 on a smaller boat would be a lot of line, hence why I like my 4-1/16-1 macro/micro tune. I have harken 57mm singles on the boom, and a fiddle on my traveler. Then 40mm?!?! or there abouts for the micro tune, a double and a fiddle. Works well.
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #15 of 31 Old 05-04-2009 Thread Starter
I don't discuss my member
zz4gta's Avatar
blt2ski, do you have a picture of the tackle? Also, what line are you using?
Merit 25 # 764 "Audrey"
zz4gta is offline
post #16 of 31 Old 05-04-2009
blt2ski's Avatar
Unfortunately, I do not have a pic with the micro, I do with it just 4-1. The micro 4-1 goes on the last length of the current setup.
If you go to harkens online page 18 of their catalong, and the lowest left mainsheet system is what I have.
I use all XLS extra lines for sheets and halyards. IIRC the main sheet is 9/16 possibly 5/8, more for comfort. The micro line is 1/4" just long enough to go from the fiddle to the boom.
Now that I added the last two pics, which are closeups, I am see that the mainsheet blocks are the old ones. BUT< they still show what I have. I can get an updated later today/tonight if need be.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #17 of 31 Old 05-04-2009
I won't comment on the block issue, but I just replaced my main sheet with New England Sta Set-colored. My boat is set up for cruising, and I know this line is a bit of a compromise as there is slightly more stretch than others but the sheet has a nice feel, runs through the blocks much better than the old Sta set it replaced, works well for my center boom rigging, and is reasonably priced/durable. If you are racing competitively, you'll likely find you'll want something a bit higher tech/expensive/stiff. My gripe with those types of lines has been that I dont like how they feel for sheets. My halyards are Sta Set X, which feels much more stiff. I know others use it for sheets though-just my preference and 2 cents. Lots of choices.
Brucerobs2 is offline
post #18 of 31 Old 05-04-2009
blt2ski's Avatar
Bruce,
No problems with your line thoughts. I do race, hence why I actually removed the sta-set from my boat. ZZ also races. I also have a carbon 155, and equal main, so why have lines that stretch more than the sail cloth etc. My reasons for the XLS line.
ALso why I like the micro tune, a little better fine control tune to the main when going up wind.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #19 of 31 Old 05-04-2009
Makes sense
That makes perfect sense. I thought that might be the case after I read saw the kind of boat you own in your profile (and after sending my response-doh). Im not sure my boat would know the difference, but yours clearly would. Good luck this season. Maybe we'll see you on the bay-SV Endurance.
post #20 of 31 Old 05-04-2009 Thread Starter
zz4gta's Avatar
I think I may opt for the 40mm although that may be pushing the standard working load a bit.
zz4gta is offline
Controlling LinesóCleats, Clutches and Jammers sailingdog Gear & Maintenance 7 04-30-2009 07:19 PM
Could you do COB recovery by yourself? davidpm General Discussion (sailing related) 77 04-17-2009 08:50 PM
Fishing Under Sail Don Casey Her Sailnet Articles 0 04-18-2002 08:00 PM
Mainsheet Systems Dan Dickison Gear and Maintenance Articles 0 10-22-2001 08:00 PM
Setting Up Reefing Tackle Dan Dickison Seamanship Articles 0 01-11-2001 07:00 PM
